Jetson AGX Orin - AQR113C SPI Flash Firmware
Our customer is developing a custom carrier board for Jetson AGX Orin, based on the Developer Kit reference design, using the Marvell AQR113C 10GbE PHY.
The reference schematic shows an external SPI flash used to configure the AQR113C.
Could you please clarify:
  • Is the AQR113C SPI flash firmware/configuration image used on the Jetson AGX Orin Developer Kit available?
  • Is there a recommended tool or procedure for programming it?
  • Can the same image be used on a custom carrier board, or does it require board-specific configuration?
Hardware:
  • Jetson AGX Orin 64GB
  • P/N: 900-13701-0050-000
  • PHY: Marvell AQR113C
The relevant schematic section is attached.
Thank you.
Hi @omer.faruk1,
Here are answers and recommended procedures regarding the Marvell AQR113C 10GbE PHY SPI flash firmware for your custom Jetson AGX Orin carrier board design:
1. Firmware / Image Availability
  • The AQR113C PHY requires an external SPI flash populated with Marvell’s PHY firmware to boot and load PHY provision settings.
  • The standard PHY firmware image binary used on the AGX Orin Developer Kit (P3737 carrier board) is included within the Jetson Linux (L4T) BSP driver overlay under /lib/firmware/ (specifically under marvell/ or aquantia/ firmware directories) as well as the NVIDIA Jetson Linux BSP Hardware Documentation package.
2. Programming Procedure & Tools
There are two main methods to flash the SPI ROM:
  • Pre-assembly Programming (Recommended for Production): Program the external SPI Flash chip (e.g. Winbond W25Q series or Macronix NOR Flash) directly using an off-board SPI IC programmer (such as DediProg or Flashpro) prior to board assembly.
  • In-System Programming (ISP) via MDIO: If the board is already powered and running Jetson Linux, you can program the SPI ROM directly from the Orin host via the MDIO bus using Marvell’s aqflash / Aquantia Flash Utility tool:
    # Example syntax for aqflash tool over MDIO bus
    sudo ./aqflash -i eth0 -f AQR113C_firmware.bin
3. Custom Carrier Board Image Compatibility
  • Direct Image Reuse: The stock Developer Kit AQR113C SPI image can be used directly on your custom carrier board if your hardware pin-strapping matches the P3737 reference schematic exactly:
    • Same PHY MDIO address
    • Same interface configuration (USXGMII / 10GBASE-T mode)
    • Matching LED pin assignments & MDI polarity settings
  • Custom Configuration: If your board uses different pin-strappings or MDIO addresses, you will need to generate a custom PHY configuration binary using Marvell’s AQR Provisioning Tool before burning it to the SPI Flash.
Make sure to verify the hardware strapping pins on your schematic against Table 6-1 of the AGX Orin Carrier Board Design Guide before board bring-up!
