Hi, I use jetpack 34.1.1, and develop the ar0233-gw5200-max9295 camera driver like jetson agx xavier, but now when I receive the data from camera it failed like below:
[ 58.183874] [RCE] NVCSILP clock rate = 408000000 Hz.
[ 58.183883] [RCE] VI5: tegra_vi_channel_alloc()
[ 58.183884] [RCE] VI5: unit 0 stream ID table:
[ 58.183885] [RCE] VI5: unit 0 stream ID table from THI:
[ 58.183886] [RCE] VI5: FALCON_CSB_AFBIF_STREAMID_CTL = 0x00
[ 58.183887] [RCE] VI5: vi5_trace_enable: configuring trace buffer at iova=0xc55dda00 size=32768
[ 58.183888] [RCE] VI5: tegra_vi_channel_alloc: ch=35
[ 58.183888] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
[ 58.183889] [RCE] VI5: channel_submit(35, bfebf000)
[ 58.183890] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
[ 58.183891] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
[ 58.183892] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
[ 58.183893] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
[ 58.183893] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
[ 58.183894] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
[ 58.183895] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
[ 58.183896] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
[ 58.183897] [RCE] VI5: enabling stream 0
[ 58.183897] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
[ 58.183898] [RCE] VI5: channel_submit(35, bfebf180)
[ 58.183899] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
[ 58.183900] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
[ 58.183901] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
[ 58.183901] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
[ 58.183902] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
[ 58.183904] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
[ 58.183905] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
[ 58.183906] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
[ 58.196120] bwmgr API not supported
[ 58.204980] max9296_read_reg_Dser: i2c read ok, 0x1 = 0x2
[ 58.205218] -- jefby Max9296 reg_addr 0x0001=0x2
[ 58.205427] max9296_read_reg_Dser: i2c read ok, 0x13 = 0xde
[ 58.205543] -- jefby Max9296 reg_addr 0x0013=0xde
[ 58.205751] max9296_read_reg_Dser: i2c read ok, 0x6 = 0xdf
[ 58.205867] -- jefby Max9296 reg_addr 0x0006=0xdf
[ 58.206037] max9296_write_reg_Dser: i2c write ok, 0x2 = 0xf3
[ 58.206316] max9295_write_reg_Ser: i2c write ok, slaveAddr 0x80 regAddr 0x2 = 0xf3
[ 58.239875] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[ 58.239880] [RCE] MIPI clock = 1666666 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[ 58.239884] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
[ 58.239887] [RCE] nvcsi_calc_ths_settle ths_settle 48
[ 58.239890] [RCE] nvcsi_calc_ths_settle ths_settle 48
[ 58.239893] [RCE] nvcsi_calc_ths_settle ths_settle 48
[ 58.239896] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
[ 58.239900] [RCE] Deskew setup message sent for port 0 num_lane 4
[ 60.896021] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 60.896277] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 60.897392] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 60.897595] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 60.897869] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 60.898082] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 60.898505] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 60.927865] [RCE] VI5: tegra_vi_channel_release(35)
[ 60.927868] [RCE] VI5: vi5_channel_disable(35)
[ 60.927870] [RCE] VI5: vi5 reset completed in 1 retries
[ 60.927872] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x00
[ 60.927874] [RCE] VI5: disabling stream 0
[ 60.927876] [RCE] VI5: tegra_vi_channel_alloc()
[ 60.927877] [RCE] VI5: tegra_vi_channel_alloc: ch=35
[ 60.927879] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
[ 60.927881] [RCE] VI5: channel_submit(35, bfebe000)
[ 60.927883] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
[ 60.927884] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
[ 60.927886] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
[ 60.927888] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
[ 60.927889] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
[ 60.927890] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
[ 60.927891] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
[ 60.927892] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
[ 60.927893] [RCE] VI5: enabling stream 0
[ 60.927894] [RCE] VI5: PFSD enabled for channel: NO, expected_count. 0
[ 60.927895] [RCE] VI5: channel_submit(35, bfebe180)
[ 60.927895] [RCE] VI5: completion_actions[8] size = 30, next offset = 314
[ 60.927896] [RCE] VI5: completion_actions[0] size = 31, next offset = 345
[ 60.927897] [RCE] VI5: completion_actions[2] size = 14, next offset = 359
[ 60.927898] [RCE] VI5: completion_actions[1] size = 30, next offset = 389
[ 60.927899] [RCE] VI5: completion_actions[4] size = 14, next offset = 403
[ 60.927900] [RCE] VI5: completion_actions[3] size = 14, next offset = 417
[ 60.927901] [RCE] VI5: completion_actions[5] size = 2, next offset = 419
[ 60.927901] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x01
[ 63.424419] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 63.424718] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 63.425427] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 63.425649] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 63.425945] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 63.426170] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 63.426929] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 63.427794] max9296_write_reg_Dser: i2c write ok, 0x2 = 0x3
[ 63.428263] max9295_write_reg_Ser: i2c write ok, slaveAddr 0x80 regAddr 0x2 = 0x3
[ 63.436955] bwmgr API not supported
[ 63.447867] [RCE] VI5: tegra_vi_channel_release(35)
[ 63.447983] [RCE] VI5: vi5_channel_disable(35)
[ 63.447983] [RCE] VI5: vi5 reset completed in 1 retries
[ 63.447985] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x00
[ 63.447986] [RCE] VI5: disabling stream 0
[ 63.447987] [RCE] VI5: tegra_vi_channel_alloc()
[ 63.447988] [RCE] VI5: tegra_vi_channel_alloc: ch=35
[ 63.447988] [RCE] VI5: tegra_vi_channel_release(35)
[ 63.447989] [RCE] VI5: vi5_channel_disable(35)
[ 63.447990] [RCE] VI5: vi5 reset completed in 1 retries
[ 63.447991] [RCE] VI5: vi5_update_streams: ch=35 stream_mask=0x00
and I changed the rce with url ERROR: NULL VI channel received, VIFALC_TDSTATE. How can I deal with it?
Can you help me? Thanks
