Jetson agx orin can not flash with JP5.1.2
Dear all:
 1: JP5.1_R35.2.1 + agx orin + custom board,  `sudo ./flash.sh -r jetson-agx-orin-devkit internal`
     flash is success.
 2: JP5.1.2_R35.4.1 + agx orin + custom board,`sudo ./flash.sh -r jetson-agx-orin-devkit internal`
      flash failed.  the log  paste in the following.
jp5.1.2_agx_orin_cannot_flash.log (74.7 KB)
3:   tegra234-mb2-bct-common.dtsi   --->  cvb_eeprom_read_size  change to 0x0.
4:  lsusb:
So, did i miss anything about agx orin in JP5.1.2?
please also share the uart log during flash failure.
not olny JP5.1, but also JP5.1.2, did not have uart log during flash.
Then there is nothing I can help. Seems to be your custom board problem.
agx xavier can flash JP5.1.2 use the same custom board.
agx xavier do not have log during flash we will check it about log.
基本上這裡的問題看來就是你的底板不管怎樣uart log都印不出來.
你得先把這個修好我們才能進一步幫你看你的Orin flash為何沒辦法過.
