How can I turn it recovery mode.
I have followed the post Jetson AGX Orin can't turn into force recovery mode nd Im still struggling. The recommended RMA solution is not an option for me please assist.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Sometimes it is the Jetson is already in recovery mode but your host PC cannot detect it.
For example, bad usb cable or using a VM as ubuntu host which makes usb detection problem.
Sometimes it is just you plug the wrong type C port on Jetson. Only one port could be used as flash port…
