Jetson AGX Orin crashes unexpectedly while running
I am using two Jetson AGX Orin units.
Power is supplied via the included terminal block, with a 5A power supply used for Jseton units A and B.
Each Jetson unit uses four cameras via a hub for inspection using an AI model. During inspection, unit A suddenly shuts down intermittently.
Logging with tegrastats and checking power, CPU/GPU, and temperature just before the shutdown reveals no particular abnormalities.
I tried reversing the connection of A and B, and unit A shut down again, so I suspect the PC itself is not the cause. Also, since unit B is not shutting down, I believe the problem lies with the PC peripherals, but I don’t know the root cause, so I would appreciate your help.
Hello @yuki.ogawa!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
~0708
Which JetPack SW you’re using?
Could you use the serial console log from UART to check the board?
