Hello NVIDIA community,
We are working on a custom Jetson AGX Orin carrier board running BSP L4T 36.3.0 (JetPack 6.0+).
In our system, we have configured and enabled 4 high-speed UART ports. However, while UART1 (ttyTHS1) and UART2 (ttyTHS2) function completely fine, we are facing an issue where UART4 (ttyTHS4) and UART5 (ttyTHS5) fail to communicate (no data transmission/reception).
Below are our system logs and current device tree / pinmux configurations. We would greatly appreciate any guidance on what might be misconfigured.
uart_bug.txt (436.0 KB)
Checking pinconf-groups for the relevant UART pins shows the following state:
sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinconf-groups | grep uart
88 (uart2_tx_px4):
function=uartb
89 (uart2_rx_px5):
function=uartb
90 (uart2_rts_px6):
function=uartb
91 (uart2_cts_px7):
function=uartb
92 (uart5_tx_py5):
function=uarte
93 (uart5_rx_py6):
function=uarte
94 (uart5_rts_py7):
function=uarte
95 (uart5_cts_pz0):
function=uarte
120 (uart1_cts_pr5):
function=uarta
121 (uart1_rts_pr4):
function=uarta
122 (uart1_rx_pr3):
function=uarta
123 (uart1_tx_pr2):
function=uarta
125 (uart4_cts_ph6):
function=uartd
126 (uart4_rts_ph5):
function=uartd
127 (uart4_rx_ph4):
function=uartd
128 (uart4_tx_ph3):
function=uartd
Here is how uart5 and uart4 are currently defined in our device tree pinmux section:
uart5_tx_py5 {
nvidia,pins = "uart5_tx_py5";
nvidia,function = "uarte";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
uart5_rx_py6 {
nvidia,pins = "uart5_rx_py6";
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
uart5_rts_py7 {
nvidia,pins = "uart5_rts_py7";
uart5_cts_pz0 {
nvidia,pins = "uart5_cts_pz0";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
uart4_tx_ph3 {
nvidia,pins = "uart4_tx_ph3";
nvidia,function = "uartd";
uart4_rx_ph4 {
nvidia,pins = "uart4_rx_ph4";
Questions:
Are there any pinmux, device tree, or clock configurations missing that would cause ttyTHS4 and ttyTHS5 to fail while ttyTHS1 and ttyTHS2 work properly on L4T 36.3.0?
Any help or suggestions would be greatly appreciated. Thank you!
