Based on the provided context, I’ll address the issues you’re facing with your custom carrier board for the Jetson AGX Orin module.
Issue 1: Longer boot time
The boot time of your custom carrier board is significantly longer (1 minute more) compared to the Jetson AGX Orin Developer Kit. This could be due to several reasons:
- Device tree configuration: The device tree configuration might not be optimized for your custom carrier board. The Jetson AGX Orin Developer Kit has a pre-configured device tree that is optimized for its specific hardware. You may need to modify the device tree configuration to match your custom carrier board’s hardware.
- Kernel configuration: The kernel configuration might not be optimized for your custom carrier board. The Jetson AGX Orin Developer Kit has a pre-configured kernel that is optimized for its specific hardware. You may need to modify the kernel configuration to match your custom carrier board’s hardware.
- Firmware loading: The firmware loading process might be taking longer on your custom carrier board. You can try to optimize the firmware loading process or use a different firmware loading mechanism.
Issue 2: No display output via DP
You’re not getting any display output via DP even after full system boot. This could be due to several reasons:
- Display controller configuration: The display controller configuration might not be correct for your custom carrier board. The Jetson AGX Orin Developer Kit has a pre-configured display controller configuration that is optimized for its specific hardware. You may need to modify the display controller configuration to match your custom carrier board’s hardware.
- DP port configuration: The DP port configuration might not be correct for your custom carrier board. You may need to modify the DP port configuration to match your custom carrier board’s hardware.
- Firmware issues: Firmware issues might be preventing the display output via DP. You can try to update the firmware or use a different firmware version.
Comparison with Jetson Orin Nano
The Jetson Orin Nano is a different module compared to the Jetson AGX Orin. While the Jetson Orin Nano has a similar architecture, it has different hardware components and configurations. Therefore, the issues you’re facing with your custom carrier board for the Jetson AGX Orin module might not be directly applicable to the Jetson Orin Nano.
However, if you’re planning to design a custom carrier board for the Jetson Orin Nano, you can follow similar steps to optimize the device tree configuration, kernel configuration, and firmware loading process. Additionally, you’ll need to ensure that the display controller configuration and DP port configuration are correct for the Jetson Orin Nano.
Recommendations
To resolve the issues with your custom carrier board for the Jetson AGX Orin module, I recommend the following:
- Review the device tree configuration and kernel configuration to ensure they are optimized for your custom carrier board’s hardware.
- Modify the display controller configuration and DP port configuration to match your custom carrier board’s hardware.
- Optimize the firmware loading process or use a different firmware loading mechanism.
- Update the firmware to the latest version or try a different firmware version.
If you’re planning to design a custom carrier board for the Jetson Orin Nano, follow similar steps to optimize the device tree configuration, kernel configuration, and firmware loading process. Additionally, ensure that the display controller configuration and DP port configuration are correct for the Jetson Orin Nano.
