I am trying to install the Deepstream SDK 7.0 on my Jetson AGX Orin board by following the official documentation. I ensured that all dependencies are installed properly and then i installed the SDK but when i am trying to verify the expected output as per given Expected Output …I am getting the following errors
(gst-plugin-scanner:306221): GStreamer-WARNING **: 19:10:42.834: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:306221): GStreamer-WARNING **: 19:10:43.508: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
** ERROR: main:706: Failed to set pipeline to PAUSED
i could not run the command directly so here are the steps i followed and the 1.log that i got
Step:1 → export GST_DEBUG=4
Step:2 → sudo bash -c ‘deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt >1.log 2>&1’
why do you need to use sudo? please execute “export GST_DEBUG=6” first, then share 2.log of “deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt >2.log 2>&1”
could you share the 3.log and 4.log after testing the following two command-lines?
i have to use sudo as the orin is not personally mine and is owned by some organisation so i don’t have the root access and hence it shows me permission denied if i run without the sudo and here is the 2.log file 2.log (2.0 KB)
similarly i have also used the sudo bash -c for these 3.log and 4.log to avoid permission issues 3.log (6.8 KB) 4.log (501 Bytes)
after setting type=1 in sink0 here’s the output that i am getting deepstream sample run.txt (83.0 KB)
Atleast the app is running now. Thank you very much!! however i am not sure if the out was as expected as i am using the orin board remotely via terminal ssh and hence i am not able to visualize the output, so can you suggest me any other possible way to visualize this as i tried to use vnc but it is lagging tooo muchh.
hey there, actually i am trying to run a pre-trained insightface scrfd face detection model on the deepstream but i am facing issue with parsing of bounding boxes. I have the simplified onnx format of the model which takes input in shape (1,3,640,640) and returns confidence score in following 3 bindings/tensors (12800,1)(3200,1)(800,1), bounding boxes in following 3 bindings/tensors (12800,4)(3200,4)(800,4),and 5 keypoints in following 3 bindings/tensors (12800,10)(3200,10)(800,10).
Here are the config files that i am using dstest1_pgie_config.txt (3.0 KB) myconfig.txt (3.8 KB)
i also tried to use python bindings by running the following file but could not do it copy_test1.txt (6.6 KB)
