Hi Wayne
Here is the lscpci log:
0005:01:00.0 Ethernet controller: Mellanox Technologies MT2910 Family [ConnectX-7]
Subsystem: Mellanox Technologies MT2910 Family [ConnectX-7]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 204
IOMMU group: 6
Region 0: Memory at 2800000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at 2b28000000 [virtual] [disabled] [size=1M]
Capabilities: [60] Express (v2) Endpoint, IntMsgNum 0
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 32GT/s, Width x16, ASPM not supported
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 16GT/s (downgraded), Width x8 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+ NROPrPrP- LTR-
10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit+ 64bit+ 128bitCAS+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
AtomicOpsCtl: ReqEn-
IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
LnkCap2: Supported Link Speeds: 2.5-32GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 32GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [48] Vital Product Data
Product Name: NVIDIA ConnectX-7 Adapter Card, 200GbE / NDR200, Dual-port QSFP112, PCIe 5.0x16 with x16 PCIe extension option, Crypto Disabled, Secure Boot Enabled
Read-only fields:
[PN] Part number: MCX755106AS-HEAT
[EC] Engineering changes: A9
[V2] Vendor specific: MCX755106AS-HEAT
[SN] Serial number: MT2526600609
[V3] Vendor specific: 1cd8e602d14ff0118000d89424dbd06e
[VA] Vendor specific: MLX:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0:MODL=CX755106A
[V0] Vendor specific: PCIeGen5 x16
[VU] Vendor specific: MT2526600609MLNXS0D0F0
[RV] Reserved: checksum good, 1 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18
Capabilities: [3b0 v1] Physical Layer 32.0 GT/s
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
0005:01:00.1 Ethernet controller: Mellanox Technologies MT2910 Family [ConnectX-7]
Latency: 0
Interrupt: pin B routed to IRQ 204
IOMMU group: 6
Region 0: Memory at 2802000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at 2b28100000 [virtual] [disabled] [size=1M]
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Read-only fields:
[VU] Vendor specific: MT2526600609MLNXS0D0F1
End
