Jetson AGX Orin Dimensional Tolerance Question
I am doing the mechanical design of an airborne electronic device that uses the Jetson AGX Orin Industrial module. Please see the attached drawing. I need to know the tolerance on the 11.18mm dimension shown in the drawing. Note that this drawing/dimension is taken directly from the 3D model of the device provided by Nvidia. Also note that this dimension is from the outer surface of the TTP to the Molex connector-side of the PCB and is not the 11.29mm dimension shown in the Nvidia I am working more in depth on this project now and have another question. Please see the attached drawing. I need to know the tolerance on the 11.18mm dimension shown in the drawing. Note that this drawing/dimension is taken directly from the 3D model of the device provided by nVidia. Also note that this dimension is from the outer surface of the TTP to the Molex connector-side of the PCB and is not the 11.29mm dimension shown in the Nvidia module data sheet, page 53, which includes the small gap above the PCB.
Thank you!
Ray Proud
nVidia Jetson AGX Orin Tolerance Question.pdf (8.4 KB)
Thank you for the detailed explanation of your question and for attaching the drawing. I passed it to the Mechanical Engineering team and should have a reply soon.
Chris,
Good afternoon – has there been any progress on this? I need an answer to this question very soon because I cannot proceed with my design without this information.
Thank you!
Ray
The tolerance of the 11.18 dimension called out in your drawing is +/-0.29 mm. This is from the top of the TTP, the solder dots on the top side of the PCB, through to the whole PCB itself, not including the solder dots on the bottom side of the PCB.
Thank you very much!
