I have XS2000 Portable SSD High-performance external drive from Kingston which I want to use to transfer data from my host PC to the Orin device, this external drive connects with USB Type-C from both sides, I have data that I want to export to the Orin using this SSD but when connecting it to the Orin it does not recognize it at all, so how to solve this problem? do I need a special driver? and thank you.
Normally that wouldn’t require an extra driver (though it is still possible it does). If you monitor “dmesg --follow
” on the Orin, and watch that as you connect the USB cable, what extra log lines show up from the USB plugin?
