Jetson AGX Orin Industrial Module - 3G vs 5G vibration testing
The datasheet for the AGX Orin series modules includes some information regarding vibration testing.
Specifically for the Industrial variation, the table below displays 3G Op and 5G Op, but both of these specify 2.83 Grms.
Is there a typo and 5G should refer to a ≈5 Grms test on this or are these only naming conventions for the specifications and 2.83 Grms is the correct figure for both specs?
This is not a typo — both 2.83 Grms is correct.
“3G” and “5G” refer to the peak shake intensity, while “Grms” is the total vibration energy across all frequencies.
A simple analogy: imagine shaking a water bottle two ways:
  • 3G: moderate but steady shaking
  • 5G: harder but shorter bursts
Both move the same total amount of water — that’s why the Grms is the same (2.83) even though the peak intensity differs.
