When i use Jetson Agx Orin to install framos-common-driver Error, it told me can’t find ‘/boot/extlinux/exlinux.conf’,
and i creat it ,it told me ERROR Unknown platform!!How should i do!
Have somebody help me?
I know nothing about framos. Do you have a reference URL on what files are installed for this? If this really is a kernel space driver, then it would need to be built against the Jetson’s kernel, and this kernel is not typically standard. The boot chain is also often not standard, and if an extlinux.conf file is incorrectly edited, then the system might not boot.
Also, could you provide the output of:
head -n 1 /etc/nv_tegra_releasecat /etc/nv_boot_control.confuname -r
Thanks, my colleague modified some parameters, which caused the machine to fail to start now. I will wait until I reinstall the system.
I have the exact same problem, please help!
I re-flashed my system, so reinstalling the driver package should suffice.
