Hi NVIDIA Team,
We are designing a custom carrier board for the Jetson AGX Orin 32GB/64GB modules, with compatibility for the AGX Orin Industrial module.
We are currently reviewing the PCIe WAKE# circuit and would like to clarify the power behavior of VDDIO_AO_3V3 in the S5 (Power Off) state.
According to Figure 7-4 (“PCIe Signal Connections – Endpoint”) in the Jetson AGX Orin Series Design Guide, the PEX_WAKE_N (A8) signal has an internal 47kΩ pull-up to VDDIO_AO_3V3.
Our questions are:
1. Is VDDIO_AO_3V3 still powered in S5 (Power Off)?
When the Jetson AGX Orin is shut down using poweroff, does the internal VDDIO_AO_3V3 rail remain at 3.3V, or is it completely powered off?
Does this behavior differ between the standard AGX Orin and AGX Orin Industrial modules?
2. What happens to the internal 47kΩ pull-up on PEX_WAKE_N (A8) during S5?
If VDDIO_AO_3V3 is powered off, is the internal pull-up effectively unavailable?
Should we expect PEX_WAKE_N to be floating or pulled low during S5 when no external circuit is driving it?
3. Is an external pull-up required or recommended?
Our carrier board has an independent 3.3V Always-On power supply that remains active during S5.
Is it safe to add an external pull-up from PEX_WAKE_N (A8) to this carrier-board 3.3V Always-On rail?
Could doing so cause back-powering or leakage into the module when the module is powered off?
4. What is NVIDIA’s recommended hardware implementation for PCIe WAKE# when supporting both S5 and SC7?
Our board uses four PCIe Ethernet controllers:
2 × Intel I210
2 × Intel I226
One I226 is directly connected to the AGX Orin PCIe Root Port.
The remaining three Ethernet controllers are connected through a PCIe Switch.
All four Ethernet ports are required to support Wake-on-LAN in both S5 and SC7.
Our proposed design is:
S5: Ethernet PE_WAKE_N signals trigger an external always-on EFM8 power management MCU, which powers on the AGX Orin.
SC7: Ethernet PE_WAKE_N signals assert the AGX Orin PEX_WAKE_N (A8) input to wake the SoC directly.
We plan to use open-drain buffering to isolate the always-on Ethernet wake signals from the module.
Would NVIDIA recommend isolating PEX_WAKE_N (A8) from the external always-on wake circuit during S5, or can an open-drain pull-down circuit remain connected to A8 in both states without an external pull-up?
Also, is PEX_WAKE_N (A8) supported as an SC7 wake source by the standard Jetson Linux BSP, or is additional PMC/device-tree configuration required?
I have attached the relevant schematic excerpts for reference.
Thank you for your support.
