Jetson AGX Orin: iwlwifi firmware crash loop (ADVANCED_SYSASSERT / Queue stuck) and gateway unreachable
Hello NVIDIA team,
We are seeing a persistent Wi-Fi failure on a Jetson AGX Orin system. The Wi-Fi link reports good signal strength and appears to be associated with the access point, but the Jetson cannot reliably ping the default gateway.
The kernel log indicates that the Intel iwlwifi firmware/driver is repeatedly becoming unresponsive, asserting, and requesting a hardware restart.
System information visible in the log
  • Platform: NVIDIA Jetson AGX Orin Developer Kit / Jetson
  • Kernel: 5.10.216-tegra #81
  • BIOS: 6.0-37391689 08/28/2024
  • Driver: iwlwifi with iwlmvm, mac80211, and cfg80211
  • PCI BDF: 0001:01:00.0
  • Loaded firmware: 59.601f3a66.0 cc-a0-59.ucode
  • Exact JetPack/L4T release: not yet confirmed
  • Wi-Fi module PCI ID/model: not yet confirmed
Symptoms
  • Wi-Fi signal strength is good.
  • The interface appears connected, but the default gateway becomes unreachable.
  • The problem repeats continuously rather than being a one-time disconnect.
In the attached log, during approximately 462 seconds, we counted:
  • 28 occurrences of Hardware restart was requested
  • 28 occurrences of ADVANCED_SYSASSERT
  • 28 occurrences of a stuck transmit/command queue
  • 27 firmware command timeouts
A typical failure cycle is:
iwlwifi 0001:01:00.0: Queue 2 is stuck 2 29
iwlwifi 0001:01:00.0: Error sending CMD_DTS_MEASUREMENT_TRIGGER_WIDE: time out after 2000ms.
iwlwifi 0001:01:00.0: Loaded firmware version: 59.601f3a66.0 cc-a0-59.ucode
iwlwifi 0001:01:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
iwlwifi 0001:01:00.0: 0x20000074 | ADVANCED_SYSASSERT
ieee80211 phy0: Hardware restart was requested
iwlwifi 0001:01:00.0: Failed to send the temperature measurement command (err=-110)
There are also timeouts for STATISTICS_CMD. One scan request failed with:
iwlwifi 0001:01:00.0: Error sending SCAN_REQ_UMAC: time out after 2000ms.
iwlwifi 0001:01:00.0: Scan failed! ret -110
WARNING: CPU: 4 ... at net/mac80211/scan.c:434 ieee80211_scan_completed ...
The log does not show PCIe AER errors or the device disappearing from PCIe. It also does not contain an explicit thermal shutdown message. Therefore, the temperature-command timeout seems more likely to be a consequence of the unresponsive firmware than proof of overheating.
Questions
  1. Is this a known issue with the Jetson 5.10.216-tegra iwlwifi/mac80211 stack and cc-a0-59.ucode?
  2. Which NVIDIA-supported kernel/driver and linux-firmware combination is recommended for this Wi-Fi device on Jetson AGX Orin?
  3. Is updating to a newer JetPack/L4T release recommended, or is there a supported driver/firmware update for this kernel branch?
  4. Are there known power-management, PCIe ASPM, Bluetooth coexistence, or scanning-related workarounds for this failure pattern?
  5. Which additional logs or iwlwifi debug parameters would be useful to identify the initial firmware failure?
The available dmesg.txt is attached. It begins in the middle of the first firmware dump, so we will also try to collect a complete boot log and the following information:
cat /etc/nv_tegra_release
uname -a
lspci -nnk -s 0001:01:00.0
lspci -vv -s 0001:01:00.0
ethtool -i <wifi-interface>
ls -lh /lib/firmware/iwlwifi-cc-a0-*
journalctl -k -b
Could you please advise on the likely root cause and the recommended supported fix?
Thank you.
Hi
There are some related topics:
Making sure you're not a bot!
[Jetpack 6.2] Intel AX200
Enable AX210 WIFI module
Please take a look and give it a try.
The posts mentioned above didn’t help; it looks like the Wi-Fi firmware is crashing?
Is there a way to reset the PCIe Wi-Fi module?
Please rmmod and modprobe the module for a try.
Reloading the driver didn’t help; the problem persists.
We follow the post:
Jetpack 6 Wifi slow startup with backport-iwlwifi-dkms - #13 by dakejahl
And test Intel8265 on Orin Nano developer kit/Jetpack 6.2.2, and can see it be enabled and run correctly:
nvidia67@nvidia67-desktop:~$ sudo modprobe iwlwifi
nvidia67@nvidia67-desktop:~$ sudo lspci -v
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 190, IOMMU group 3
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        I/O behind bridge: [disabled]
        Memory behind bridge: 40000000-400fffff [size=1M]
        Prefetchable memory behind bridge: [disabled]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Secondary PCI Express
        Capabilities: [158] Physical Layer 16.0 GT/s <?>
        Capabilities: [17c] Lane Margining at the Receiver <?>
        Capabilities: [190] L1 PM Substates
        Capabilities: [1a0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2a0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [2d8] Data Link Feature <?>
        Capabilities: [2e4] Precision Time Measurement
        Capabilities: [2f0] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Capabilities: [358] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
        Kernel driver in use: pcieport
0001:01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
        Subsystem: Intel Corporation Dual Band Wireless-AC 8265
        Flags: bus master, fast devsel, latency 0, IRQ 240, IOMMU group 3
        Memory at 20a8000000 (64-bit, non-prefetchable) [size=8K]
        Capabilities: [c8] Power Management version 3
        Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [40] Express Endpoint, MSI 00
        Capabilities: [140] Device Serial Number 60-f2-62-ff-ff-b4-50-be
        Capabilities: [14c] Latency Tolerance Reporting
        Capabilities: [154] L1 PM Substates
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
Please run $ sudo lspci -v and share the print for reference. Some WIFI modules(such as AX201NGW) does not work in standard M.2 Key-E slot:
community.intel.com/t5/Wireless/AX201-AX201-NGWG-vs-AX201-NGWG-W/m-p/1377966#M41510
Would like to confirm whether your module is correctly linked up.
galbot@galbot-echo:~$ sudo lspci -v
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 64
I/O behind bridge: \[disabled\]
Memory behind bridge: 40000000-401fffff \[size=2M\]
Prefetchable memory behind bridge: \[disabled\]
Capabilities: \[40\] Power Management version 3
Capabilities: \[50\] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: \[70\] Express Root Port (Slot-), MSI 00
Capabilities: \[b0\] MSI-X: Enable- Count=8 Masked-
Capabilities: \[100\] Advanced Error Reporting
Capabilities: \[148\] Secondary PCI Express
Capabilities: \[168\] Physical Layer 16.0 GT/s <?>
Capabilities: \[18c\] Lane Margining at the Receiver <?>
Capabilities: \[1ac\] L1 PM Substates
Capabilities: \[1bc\] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: \[2bc\] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: \[2f4\] Data Link Feature <?>
Capabilities: \[300\] Precision Time Measurement
Capabilities: \[30c\] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: \[374\] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0000:01:00.0 Ethernet controller: Intel Corporation Device 0d9f (rev 03)
Subsystem: Intel Corporation Device 0000
Memory at 2728000000 (32-bit, non-prefetchable) \[size=1M\]
Memory at 2728100000 (32-bit, non-prefetchable) \[size=16K\]
Capabilities: \[70\] MSI-X: Enable+ Count=5 Masked-
Capabilities: \[a0\] Express Endpoint, MSI 00
Capabilities: \[140\] Device Serial Number 94-c9-b7-ff-ff-60-3b-b6
Capabilities: \[1c0\] Latency Tolerance Reporting
Capabilities: \[1f0\] Precision Time Measurement
Capabilities: \[1e0\] L1 PM Substates
Kernel driver in use: igc
Kernel modules: igc
Flags: bus master, fast devsel, latency 0, IRQ 66
Memory behind bridge: 40000000-400fffff \[size=1M\]
Capabilities: \[50\] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: \[b0\] MSI-X: Enable- Count=1 Masked-
Capabilities: \[158\] Physical Layer 16.0 GT/s <?>
Capabilities: \[17c\] Lane Margining at the Receiver <?>
Capabilities: \[190\] L1 PM Substates
Capabilities: \[1a0\] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: \[2a0\] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: \[2d8\] Data Link Feature <?>
Capabilities: \[2e4\] Precision Time Measurement
Capabilities: \[2f0\] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: \[358\] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0001:01:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200
Memory at 20a8000000 (64-bit, non-prefetchable) \[size=16K\]
Capabilities: \[c8\] Power Management version 3
Capabilities: \[d0\] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: \[40\] Express Endpoint, MSI 00
Capabilities: \[80\] MSI-X: Enable+ Count=16 Masked-
Capabilities: \[14c\] Latency Tolerance Reporting
Capabilities: \[154\] L1 PM Substates
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 229c (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 68
Memory behind bridge: \[disabled\]
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 70
Capabilities: \[190\] Lane Margining at the Receiver <?>
Capabilities: \[1c0\] L1 PM Substates
Capabilities: \[1d0\] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: \[2d0\] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: \[308\] Data Link Feature <?>
Capabilities: \[314\] Precision Time Measurement
Capabilities: \[320\] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: \[388\] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0005:01:00.0 Non-Volatile memory controller: Device 1d79:2267 (rev 03) (prog-if 02 [NVM Express])
Subsystem: Device 1d79:2267
Memory at 2b28000000 (64-bit, non-prefetchable) \[size=16K\]
Capabilities: \[50\] MSI: Enable- Count=1/8 Maskable+ 64bit+
Capabilities: \[70\] Express Endpoint, MSI 00
Capabilities: \[b0\] MSI-X: Enable+ Count=16 Masked-
Capabilities: \[158\] Secondary PCI Express
Capabilities: \[178\] Physical Layer 16.0 GT/s <?>
Capabilities: \[19c\] Lane Margining at the Receiver <?>
Capabilities: \[1b4\] Latency Tolerance Reporting
Capabilities: \[1bc\] L1 PM Substates
Capabilities: \[360\] Designated Vendor-Specific <?>
Capabilities: \[390\] Designated Vendor-Specific <?>
Capabilities: \[3c0\] Designated Vendor-Specific <?>
Kernel driver in use: nvme
This module exhibited an anomaly after operating normally for a period of time.
