Jetson AGX Orin Pinmux wakesource number
I use the JAOi module on a custom carrier and want to use GPIO Pins as wake sources.
Before i used the Pinmux sheet to find the correct wake source number in column “w”.
Since the Pinmux V2.1 spreadsheet is locked i can not open that column anymore and so i’m not able to see these numbers.
What is the correct way to proceed? Can you give me the password or is there now a different source for this information?
Can you double check with column AV ?
