I am using jetpack 5.1.2 with python 3.8 and I am trying to install pytorch 2.1.0 but pytorch 1.8.0 is getting installed and it is creating problem in the further process how to solve it.
Could you try to import the PyTorch and share the output of the below command with us?
$ python3
# import torch
# torch.__version__
It looks like the PyTorch in your environment has a dependency on cuBLAS 10.
So the installed version is 1.8.
Could you remove the package and re-install the PyTorch 2.1.nv23.06 package again?
Below is the checksum value of PyTorch v2.1 for your reference:
$ md5sum torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl
0063b1373e339e47995afd093a3cde87 torch-2.1.0a0+41361538.nv23.06-cp38-cp38-linux_aarch64.whl
Thanks for your support I have finally installed torch2.1.0 and torchvision0.16.1 and now i want to install ultralytics yolov8 without disturbing the version of torch and torchvision how can I do it
Hi
Ultraylytics can be installed via pip
directly.
Do you meet any issues when using it?
