Hi NVIDIA Team,
We are designing a custom carrier board based on the Jetson AGX Orin module, with the following camera configuration:
2 × MAX96712 GMSL Deserializers
Each MAX96712 connects to 4 GMSL cameras
Total: 8 GMSL cameras
Each MAX96712 requires I2C communication for configuration and camera control
We would like to confirm the recommended I2C architecture for a production design, especially regarding reliability and compatibility with the Jetson Linux BSP.
According to the Jetson AGX Orin Series Design Guide (DG-10653-001, v1.81), Table 13-2:
I2C3: Assigned to the CAM block
I2C2: Shared with on-module power monitors at addresses 0x40 and 0x41
I2C8 / I2C9: Other available I2C controllers
We are considering the following options:
Option 1: I2C3 + I2C2
I2C3 → MAX96712 #1 (4 cameras)
I2C2 → MAX96712 #2 (4 cameras)
Since I2C2 is shared with the on-module power monitors, are there any concerns about using it for GMSL camera control, such as address conflicts, bus recovery, or system reliability?
Option 2: I2C3 + I2C MUX
I2C3 → I2C MUX (e.g., TCA9548A)
MUX Channel 0 → MAX96712 #1
MUX Channel 1 → MAX96712 #2
Would this architecture be preferable for a production design?
Option 3: I2C3 + Another I2C Controller
Would NVIDIA recommend using I2C3 together with I2C8 or I2C9 instead of I2C2?
We would appreciate NVIDIA’s guidance on the following questions:
Which I2C architecture would NVIDIA recommend for two MAX96712 deserializers and eight GMSL cameras in a production system?
Is I2C2 officially suitable for external GMSL deserializer control, considering that it is shared with the on-module power monitors?
Are I2C8 and I2C9 suitable alternatives? Are there any hardware, pinmux, power-domain, or Jetson Linux BSP limitations?
Is an I2C MUX recommended for improved reliability and fault isolation, or are two independent I2C controllers preferable?
Does NVIDIA have a recommended reference design or best practice for connecting multiple MAX96712 deserializers to AGX Orin?
Our main priorities are production reliability, fault isolation, and long-term BSP compatibility.
Thank you for your support!
