[Jetson AGX orin]refalsh Jetpack
I want to reflash Jetpack but sdk manager could not detect a board. I am connecting to the host with microUSB. Should the host have a USB 3.0 port? If USB 3.0 is required, how can I confirm this? Also, I’m not sure if I have entered recovery mode. When I run lsusb on the host, I can see as follow:Bus 001 Device 009: ID 0955:7045 NVIDIA Corp. Tegra On-Platform Operator.
SDKM_logs_2024-11-27_09-33-12.zip (21.2 KB)
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Hi gao_yuyu:
You are connecting the wrong cable. microUSB is for serial port, which will dump the debug mesages. To flash your board, you need to connect your host PC and board using the type-c connector.
