Jetson agx orin removes the system graphical interface
Hi
Can I remove the system graphical interface when I customize the kernel because it takes up a lot of resources?
Also, how to trim the kernel to remove unnecessary drivers.
Please use minimal rootfs to develop your use-case:
Root File System — Jetson Linux Developer Guide documentation
Hi DaneLLL,
Thank you very much for your help, I will try the scheme you provide.
