I config the CONFIG_MODULE_SIG=n in the defconfig file,rebuild the kernel,nvidia-oot module,device tree,and flash the agx orin,but it can’t start up normal. The error is disagrees about version of symbol module_layout. If config the CONFIG_MODULE_SIG=y, it can start up normal. What is the reason for this?
The SDK version is r36.4.4, AGX Orin Developer Kit 64G
The host pc version is:
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
SDK build and flash command
make -C kernel
sudo -E make install -C kernel
cp kernel/kernel-jammy-src/arch/arm64/boot/Image ../kernel/Image
make modules
sudo -E make modules_install
make dtbs
cp kernel-devicetree/generic-dts/dtbs/* ../kernel/dtb/
sudo ./apply_binaries.sh
sudo ./tools/l4t_update_initrd.sh
sudo ./flash.sh jetson-agx-orin-devkit internal
The console and flash log:
[ 9.686465] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.686535] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.686632] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.686774] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.686927] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 9.687256] nvsciipc: disagrees about version of symbol module_layout
[ 9.688749] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.689406] mc: disagrees about version of symbol module_layout
[ 9.690367] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.690710] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.691571] typec: disagrees about version of symbol module_layout
[ 9.691714] snd_soc_rl6231: disagrees about version of symbol module_layout
[ 9.692048] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.692056] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.692087] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.692336] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.692802] at24: disagrees about version of symbol module_layout
[ 9.693566] crct10dif_ce: disagrees about version of symbol module_layout
[ 9.696848] ina3221: disagrees about version of symbol module_layout
[ 9.704108] ina3221: disagrees about version of symbol module_layout
[ 9.804118] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 9.918776] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.033620] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.147307] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.261164] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.374952] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.489038] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.603934] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.718207] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.832026] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 10.945856] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.059535] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.173010] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.286362] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.399434] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.512658] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.625862] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.738593] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.851332] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 11.964252] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.077231] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.190231] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.303209] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.415745] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.529306] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.641525] tpm_ftpm_tee: disagrees about version of symbol module_layout
[ 12.796889] nvme_core: disagrees about version of symbol module_layout
[ 12.829767] libcomposite: disagrees about version of symbol module_layout
[ 14.385628] ipv6: disagrees about version of symbol module_layout
[ 14.388849] ipv6: disagrees about version of symbol module_layout
[ 21.160044] Please complete system configuration setup on desktop to proceed.[ 25.152257] drm: disagrees about version of symbol module_layout
[ 25.919504] fuse: disagrees about version of symbol module_layout
[ 27.204388] ipv6: disagrees about version of symbol module_layout
[ 27.206822] ipv6: disagrees about version of symbol module_layout
[ 27.589993] fuse: disagrees about version of symbol module_layout
[ 27.593752] fuse: disagrees about version of symbol module_layout
console log.txt (102.9 KB)
flash log.txt (104.6 KB)
