Hi everyone,
I posted yesterday about a significant issue with my Jetson AGX Orin 64GB Developer Kit, where I was stuck on a flashing underscore (_) during boot and couldn’t enter recovery mode or proceed further. I tried numerous steps—headless connections, display setups, microSD flashing with JetPack 6.2, recovery mode attempts, and SDK Manager flashing—but nothing worked initially. I’m thrilled to report that I’ve resolved the issue, and I wanted to share the fix in case it helps others facing similar problems. Here’s what worked for me, with thanks to the support I received elsewhere (and hoping this forum can assist others in the future!):
Issue Recap
My Jetson AGX Orin was stuck at a flashing underscore on boot, with no progress.
I couldn’t enter recovery mode using the standard method (pressing the Recovery button during boot).
USB recovery attempts failed, and the device seemed unresponsive, despite checking connections and cables.
Steps I Took Initially (Without Success)
Attempted recovery mode by holding the Recovery button and pressing Reset, but the system didn’t respond.
Flashed a microSD card with JetPack 6.2 using Rufus, but since I wasn’t booting from microSD (defaulting to eMMC), it didn’t help.
Connected a display, mouse, and keyboard, but still saw the flashing underscore.
Used SDK Manager on a Windows-to-WSL Ubuntu setup initially, but it failed due to USB passthrough issues.
Rebooted multiple times, checked USB cables, and reset the Jetson, but the issue persisted.
The Fix: How I Resolved It
After persistence and detailed troubleshooting, here’s what ultimately worked, step by step, to access recovery mode, troubleshoot the flashing underscore, and reflash the device:
- Verified Recovery Mode Entry:
I ensured I was using the correct recovery sequence: Press and hold the Force Recovery button, press and release the Reset button, then release Force Recovery after 2-3 seconds while powering on via USB-C or DC jack. I used a high-quality, data-capable USB-C cable connected to the port near the 40-pin header on the Jetson.
Confirmed detection on my host PC (Dell Inspiron 5558 running native Ubuntu 24.04 LTS) with lsusb, looking for “NVIDIA Corp. APX” (0955:7023). If it didn’t appear, I rechecked the cable, port, and recovery steps.
2. Switched to a Native Ubuntu Host:
Initially, I tried using Ubuntu via WSL on Windows, but USB access was unreliable. I installed Ubuntu 24.04 LTS natively on my Inspiron 5558, wiping Windows and using a bootable USB (created with Rufus) to ensure full hardware control. This resolved USB detection issues for recovery mode and flashing.
3. Adjusted BIOS/UEFI Settings on the Host:
On my Inspiron, I entered BIOS (F2), disabled Secure Boot and Fast Boot, and set Boot Mode to UEFI (matching the GPT partition on the Ubuntu USB). This ensured stable USB detection for the Jetson.
4. Flashed JetPack 6.2 with SDK Manager:
Installed NVIDIA SDK Manager on Ubuntu 24.04 by downloading the .deb file, resolving dependencies (e.g., libcanberra-gtk-module, libgtk-3-0), and running sudo dpkg -i sdkmanager_.deb followed by sudo apt install -f if needed.
Launched SDK Manager, logged in with my NVIDIA Developer account, selected “Jetson AGX Orin (64GB) developer kit,” and chose JetPack 6.2 with eMMC as the storage device.
Ensured my Jetson was in recovery mode, connected via USB-C, and detected (confirmed with lsusb). The download completed successfully (16.92 MB total), and I proceeded to flash, setting a username (“wynand”) and password.
5. Monitored and Completed the Flash:
SDK Manager installed host components (CUDA, Nsight, etc.) and flashed the Jetson, taking 10-20 minutes. I monitored progress, ensuring the Jetson stayed in recovery mode (white LED on) and the USB connection was stable.
After flashing, I powered on the Jetson, and it booted into Ubuntu (JetPack 6.2) on its eMMC, eliminating the flashing underscore.
Key Troubleshooting Tips
Recovery Mode Challenges: If recovery mode fails, use a high-quality USB-C cable, ensure the correct port (near 40-pin header), and verify host detection with lsusb. Retry the recovery sequence multiple times if needed.
Flashing Underscore Fix: The underscore was due to a corrupted or missing bootloader/eMMC content. Flashing JetPack 6.2 via SDK Manager on a native Ubuntu host resolved it by overwriting the eMMC with a fresh image.
USB-to-UART Cable (Optional): I had a USB-to-UART cable ready but didn’t need it, as SDK Manager handled the flash. It would have been useful for serial debugging (via J26, baud 115200) if boot issues persisted post-flash.
Final Outcome
My Jetson AGX Orin now boots into JetPack 6.2 on its 64GB eMMC, with no flashing underscore. I can log in with my username (“wynand”) and password, and it’s ready for development. I also added a 1TB NVMe SSD, which I’ll format and mount post-boot for additional storage.
Gratitude and Future Support
I reached out here initially but didn’t really got helpful responses, so I sought help elsewhere and managed to resolve it with detailed, real-time guidance. I’m sharing this solution to help others and hope the Jetson Forum can assist future users facing similar issues. If anyone has questions or additional tips, I’d love to hear them—I’m now set up for Jetson projects and appreciate the community’s potential support moving forward.
Thanks for reading, and I hope this helps someone else!
Best regards,
Wynand
P.S. Flippen Painful experience
