I am designing a carrier board and larger system, where the Jetson AGX Orin SoM could see sudden power loss, if upstream power is removed. Depending on board capacitance, the specified power sequencing shutdown in the AGX Orin Design Guide may not complete before all rails go to 0 volts.
Is this a risk for internal eMMC corruption or damage?
What if it is a read only file system?
Can Nvidia provide any information on whether removal of all power rail power, faster than the shutdown sequence, will cause issues with the internal eMMC?
My external carrier board NVMe drives have PLP (power loss prevention) by having internal tantalum caps to finish I/O operations, so I do not expect this issue to exist elsewhere.
Thank you.
Thank you for the detailed question.
1. eMMC Corruption — Yes, there is risk. If a write operation is in progress when power is abruptly removed, eMMC data corruption can occur. Even with a read-only filesystem, the eMMC controller may still perform internal background operations (e.g., FTL housekeeping, wear leveling), so the risk cannot be fully eliminated.
2. Power Sequencing Violation — Yes, there is risk. When upstream power is removed abruptly, each rail decays at a different rate depending on its decoupling capacitance. This can result in:
- A higher-voltage rail remaining active while a lower-voltage rail has already collapsed
- Module I/O pins being driven above their associated power rail voltage
- These conditions can potentially trigger latch-up, which may cause permanent silicon damage
3. NVIDIA’s Guideline The Jetson AGX Orin Series Design Guide (DG-10653-001) specifies the required power-on and power-off sequencing in Section 6 (Power-On/Off Sequences). This sequencing must be followed to ensure safe operation of the module.
If your system is subject to sudden power loss, we strongly recommend:
- Adding sufficient holdup capacitance to maintain module power long enough to complete the shutdown sequence
- Implementing power-loss detection (e.g., upstream supply monitor) to assert
MODULE_POWER_ON LOW and initiate a controlled shutdown before rails collapse
Operating outside of the documented power sequencing requirements is not supported and carries risk of both eMMC corruption and potential hardware damage.
Thank you for your response.
If we can guarantee the power sequencing state, via upstream capacitance or early enough power loss detection, is it logical to assume there will be no eMMC corruption at the hardware level? e.g. FTL house keeping, wear leveling, etc? And any file system corruption occurs is a Linux level concern with file system choice, etc?
Thank you.
Could you clarify what “guarantee the power sequencing state” means in your design?
Specifically — does your design detect power loss and de-assert MODULE_POWER_ON (LOW), with sufficient holdup capacitance to allow the module’s internal PMIC to complete its full power-down sequence per the Jetson AGX Orin Design Guide, Section 5?
If yes — the PMIC shuts down all internal rails in the correct order, and there is no risk of eMMC hardware-level corruption. The remaining concern is Linux filesystem-level corruption (unflushed write caches), which can be mitigated with filesystem choices (read-only rootfs, overlayfs, etc.).
If your approach is adding bulk capacitance so rails decay slowly — that alone does not satisfy the sequencing requirement, as the PMIC is not controlling the rail discharge order.
I am intending to conform with the sequence below, by ensuring there is sufficient capacitance that when MODULE_POWER_ON goes low, the timings below are observed. The bulk capacitance would be applied on the carrier board, upstream of the regulators that provide SYS_VIN_HV, SYS_VIN_MV.
For sizing board capacitance, can you confirm the expected current draw of the module during the >=10mS between MODULE_POWER_ON going low, and the rails going down?
Will it be the consumption of the module based on operating system load, or will deasserting MODULE_POWER_ON halt the CPU/GPU and other functions, lowering the power consumption?
Thank you.
The exact current draw during shutdown is not a fixed value — it depends on what application is running and at what point the shutdown is triggered.
For holdup cap sizing, think of the shutdown process in two phases:
Phase 1: Event detection → SYS_RESET_N goes LOW This is your worst case. The system is still fully operational, so assume your maximum power consumption based on your use case. You can measure this on your system — it is the peak power draw while your application is running. The duration of this phase (the delay from event detection to SYS_RESET_N assertion) is also measurable on your carrier board.
Phase 2: SYS_RESET_N LOW → Power rails off Once SYS_RESET_N is asserted, the PMIC sequencer begins shutting down internal rails and power consumption drops rapidly. The critical requirement here is that SYS_VIN_HV and SYS_VIN_MV must remain valid until after CARRIER_POWER_ON goes LOW and your carrier board IO rails (3.3V, 1.8V) have fully discharged. This prevents back-drive into the module. Refer to DG Figure 5-5 for the detailed timing.
In summary, size your holdup capacitance for:
- Phase 1: (your max power consumption) × (event-to-SYS_RESET_N delay)
- Phase 2: maintain HV/MV through the IO rail discharge sequence per DG Figure 5-5 — power draw is significantly lower in this phase
Both the max power and the event-to-reset delay are values you can directly measure on your system.
