I see there has been some discussion around SFP+ ports on the AGX Orin recently with no real resolution. I was curious if anyone has any info on wiring it up to a Marvel 88X2120. Hardware wise it looks like it should work fine, the 88X2120 is just an XFI to SFI bridge that also integrates all the other SFP+ signals on-chip.
The big question is then in the Jetson Linux environment, if it would/could be supported, and then I’m assuming only one port could be active since it appears the Jetson only supports a single XFI, even though it should theoretically have four?
Thanks for any help or info anyone has.
