Hi NIVIDA Team,
I do channel simulation for XFI interface based on “DA-11107-001_v1.0.pdf” as below, and the eye mask is fail. So I tune the TXEQ vaule based on your document"T234_Uphy_TX_IBIS-AMI_model_readme_20200811.pdf" as below, in the end, the result of eye mask is pass.
So my question:can we tune the value through the software of AGX Orin? or which document is descriped for TXEQ Switch setting or how do we need to change this value?
Hi @lubinbin
Welcome to the NVIDIA Developer forums. Your question should be posted in the Jetson category.
I will move it over for you now.
