Hardware / Software Environment
Hardware Platform
- Jetson AGX Orin 64 GB Developer Kit
DeepStream Version
DeepStream 7.1
Docker image:
nvcr.io/nvidia/deepstream-l4t:7.1-triton-multiarch
JetPack Version
JetPack 6.2.1
L4T 36.4.4
System Setup
We are developing a visual inspection application for Jetson devices using DeepStream.
Our setup consists of two Docker containers running on the same Jetson AGX Orin:
A DeepStream 7.1 container running the video processing pipeline.
A dedicated Triton Inference Server container (
nvcr.io/nvidia/tritonserver:24.02-py3-igpu) hosting all inference models.
The DeepStream pipeline communicates with the Triton server for inference.
Problem Description
Hi all,
after running for some time (sometimes after a few hours), the Jetson unexpectedly reboots without any warning.
The reboot appears to be a full system restart rather than an application or container crash.
Running last reboot shows multiple unexpected reboots:
jetson@jetson-dev-01:~$ last reboot
reboot system boot 5.15.148-tegra Mon Jul 6 12:20 still running
reboot system boot 5.15.148-tegra Mon Jul 6 09:17 still running
reboot system boot 5.15.148-tegra Mon Jul 6 06:12 still running
reboot system boot 5.15.148-tegra Sun Jul 5 05:49 still running
reboot system boot 5.15.148-tegra Sun Jul 5 04:25 still running
reboot system boot 5.15.148-tegra Sat Jul 4 23:35 still running
Observations
While the application is running, we continuously monitor the system using jtop.
We have not observed any obvious indicators that would explain the reboot:
No abnormal GPU or CPU temperatures.
No increasing memory usage or memory leak.
No excessive CPU utilization.
No significant resource spikes before the reboot.
No fatal errors in the application logs.
No Docker container crashes before the system restarts.
From the application’s perspective, the reboot appears completely unexpected.
Questions
Could this be related to running JetPack 6.2.1 (L4T 36.4.4) instead of L4T 36.4, which is listed as the officially supported version for DeepStream 7.1?
What would be the recommended approach to identify the root cause of these unexpected system reboots?
Is connecting a serial console currently the best (or only) practical way to capture the information needed to diagnose this type of system-level crash?
Any suggestions on how to further investigate this issue would be greatly appreciated.
Thank you!
