Jetson AGX Orin Usage
I started using the Jetson AGX Orin recently for a project that involves Deep Learning and Reinforcement Learning. However, I want to make sure if the Jetson AGX Orin is made for training the models, or is it made for deploying trained models?
Which approach is the most efficient:
1- Training and deploying the model on the Orin ?
2- Training the model on a different computer and deploying it on the Orin?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Thanks for your reply, but that doesn’t clear my doubt.
I would like to know what is the main use of the Orin, is it supposed to be used for training or inference?
Most customers use AGX Orin as edge computing for inference, of course it can be used for training but the RAM might be a concern than some other host machine.
There are many AI projects sharing at Latest Jetson & Embedded Systems/Jetson Projects topics - NVIDIA Developer Forums for your reference.
Maybe you can try TAO Toolkit, and deploy to Jetson.
Ref Link Here
