我们使用了Device Kit的USB TYPE A口,接USB2.0的相机。发现有的TYPE A口无法识别相机,或者使用过程中不稳定,有时候会掉。电源已经验证只有300mA+,怀疑信号质量可能不足。看到这个TYPE A是通过USB3.2 通过4口的HUB分出来的,请问如何想要提升信号质量的话,有没有HUB的预加重、输出摆浮等设置等参数可以尝试?
Based on the provided context, it appears that you are asking about the USB configuration for the Jetson AGX Orin device kit. Here’s a comprehensive answer:
The Jetson AGX Orin device kit has multiple USB ports, including:
- USB TYPE A (x2)
- USB 2.0 TYPE A (x1)
- USB 3.2 TYPE A (x1)
- USB 3.2 HUB (x1) with 4 ports
This configuration allows for multiple USB devices to be connected to the Jetson AGX Orin device kit, including peripherals such as keyboards, mice, and storage devices.
In comparison, the Jetson Orin NX and Jetson Orin Nano device kits may have different USB configurations. However, the provided context does not specify the exact USB configuration for these devices.
It’s worth noting that the Jetson AGX Orin device kit also supports USB to SATA controllers, which can be used to connect SATA drives to the device. This is mentioned in the context as a possible configuration for the device kit.
In summary, the Jetson AGX Orin device kit has a comprehensive USB configuration with multiple ports, including USB 2.0, USB 3.2, and a USB 3.2 HUB with 4 ports. This allows for flexible connectivity options for peripherals and storage devices.
Is this issue happened with only one camera in use or multiple one?
It will happen when only one camera
What kind of camera are you using there? any model ID to share?
