Hardware / Software
- Device: Jetson AGX Thor Developer Kit (hostname “chip”)
- JetPack / L4T: 7.2 R39
- WiFi: Stock Realtek RTL8852CE (wlP1p1s0)
- SSID: Morningwood (WPA2/WPA3 mixed, multiple BSSIDs, strong signal)
- Comparison: Jetson Orin Nano Super on the same network has zero issues
Problem Summary
WiFi associates successfully but immediately drops with CTRL-EVENT-DISCONNECTED reason=15 (4-way handshake timeout). NetworkManager then fails activation with “association took too long” / “no-secrets”. Autoconnect does not recover reliably. Device eventually ends up disconnected even though the SSID is visible at high signal.
Chronology of Troubleshooting
1. Initial state check
Bash
nmcli -f connection.autoconnect,connection.autoconnect-priority,connection.autoconnect-retries,connection.autoconnect-slaves,802-11-wireless.bssid,802-11-wireless.seen-bssids,802-11-wireless.powersave connection show "Morningwood"
Output:
text
connection.autoconnect: yes
connection.autoconnect-priority: 10
connection.autoconnect-retries: -1 (default)
connection.autoconnect-slaves: -1 (default)
802-11-wireless.bssid: --
802-11-wireless.seen-bssids: 1C:0B:8B:72:F7:DE,E4:38:83:48:C8:28,...
802-11-wireless.powersave: 2 (disable)
(Note: -1 on autoconnect-retries = unlimited retries / default)
2. NetworkManager logs (excerpt)
text
device (wlP1p1s0): state change: need-auth -> prepare -> config
Activation: (wifi) connection 'Morningwood' has security, and secrets exist.
Config: added 'ssid' 'Morningwood', 'bgscan' 'simple:30:-65:300', key_mgmt WPA-PSK..., psk <hidden>
supplicant interface state: scanning -> associating
... later ...
supplicant interface state: associated -> disconnected
Activation: (wifi) association took too long
state change: config -> failed (reason 'no-secrets')
Activation: failed for connection 'Morningwood'
3. wpa_supplicant details (key failure)
text
wlP1p1s0: Trying to associate with 9c:05:d6:f5:4c:2a (SSID='Morningwood' freq=5280 MHz)
wlP1p1s0: CTRL-EVENT-STARTED-CHANNEL-SWITCH freq=5280 ht_enabled=1 ch_offset=-1 ch_width=160 MHz
wlP1p1s0: Associated with 9c:05:d6:f5:4c:2a
wlP1p1s0: CTRL-EVENT-DISCONNECTED bssid=9c:05:d6:f5:4c:2a reason=15
BSSID ... ignore list count incremented to 2
CTRL-EVENT-SSID-TEMP-DISABLED ... reason=CONN_FAILED
(reason=15 = 4WAY_HANDSHAKE_TIMEOUT)
4. Current WiFi scan (strong signal, multiple BSSIDs)
text
nmcli -f IN-USE,SSID,BSSID,SIGNAL,RATE,BARS,SECURITY dev wifi list
# Shows Morningwood at 80–95% on several BSSIDs, WPA2/WPA3, 160 MHz capable APs
iw dev wlP1p1s0 link
# Not connected
5. Attempted profile hardening (one property at a time after NM timeout/crash)
Bash
CON="Morningwood"
sudo nmcli connection modify "$CON" 802-11-wireless-security.key-mgmt wpa-psk
sudo nmcli connection modify "$CON" 802-11-wireless-security.proto rsn
sudo nmcli connection modify "$CON" 802-11-wireless-security.pairwise ccmp
sudo nmcli connection modify "$CON" 802-11-wireless-security.group ccmp
sudo nmcli connection modify "$CON" 802-11-wireless-security.pmf 1
sudo nmcli connection modify "$CON" 802-11-wireless.mac-address-randomization never
sudo nmcli connection modify "$CON" 802-11-wireless.powersave 2
sudo nmcli connection modify "$CON" connection.autoconnect yes
sudo nmcli connection modify "$CON" connection.autoconnect-priority 100
sudo nmcli connection modify "$CON" connection.autoconnect-retries 0
sudo nmcli connection modify "$CON" 802-11-wireless.bssid 9C:05:D6:F5:4C:29 # lock to strongest BSSID
- First bulk modify timed out (“Timeout was reached”)
- NetworkManager had to be restarted (systemctl restart NetworkManager / killall + start)
- Note: bgscan property is not exposed on this NM version (invalid property error)
6. Hardware swap attempt
Decided the stock RTL8852CE is the root cause (known flaky on Thor with 160 MHz / mixed WPA2/WPA3).
Have a spare Intel AX200 ready.
Physical removal blocked:**
- Removed the single M.2 screw and the small antenna cover plate.
- Card will not hinge up even 0.1 mm.
- No visible secondary latch, screw, or clip.
- Standard M.2 hinge-and-pull technique does nothing. Feels mechanically captive. Is it glued down?
Current Status
- Stock RTL8852CE still installed and still flaky.
- AX200 swap on hold until I get answers on if it is glued down and I can free the original card without damage.
- Prefer a proper M.2 solution over USB dongles.
- Unit may also require removal of radios for compliance.
Questions for the community / NVIDIA
- Has anyone successfully replaced the stock RTL8852CE on the AGX Thor Dev Kit? Is the card retained by a thermal pad or undocumented feature?
- Any confirmed working Intel AX200 / AX210 / BE200 experiences on Thor (JetPack 7.x)?
- Any driver/modprobe options or NM tweaks that reliably fix the reason=15 / 160 MHz handshake failures on the stock card?
- Is there an official NVIDIA position on swapping the M.2 WiFi module (warranty impact)?
Happy to provide full journalctl -u NetworkManager - journalctl -u wpa_supplicant, dmesg | grep -E ‘rtl|8852|iwl|wlP’`, and photos of the stuck card.
