Jetson AGX Thor Dev Kit: J81/J82 USB-C host ports not working after boot; workaround only restores one port
Hi NVIDIA Jetson team,
We are investigating a USB-C host port issue on a Jetson AGX Thor Developer Kit and would like to confirm the expected product behavior and whether there is a permanent fix planned.
Environment:
  • Product: Jetson AGX Thor Developer Kit
  • JetPack / Jetson Linux: JetPack 7.2 / Jetson Linux r39.2.0
  • Installation image: jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso
  • USB-C ports in question: J81 and J82 Type-C ports
Issue summary:
After booting the OS, USB devices connected to either Type-C port are not recognized from Linux.
However, when a device is connected, error logs are output in dmesg, so we suspect that the ports are electrically active but that the issue may be related to firmware/software behavior rather than a simple physical port failure.
Initial behavior observed:
  • J81 Type-C port:
    • Power input via AC adapter: OK
    • UEFI recognition for OS installation: OK
    • USB device recognition after Linux boot: NG
  • J82 Type-C port:
    • UEFI recognition for OS installation: NG
Actions already taken:
  1. Reinstalled JetPack 7.2 / Jetson Linux r39.2.0.
    • Result: No change. After OS boot, USB devices were still not recognized on either Type-C port.
  2. Applied the workaround described in the Jetson Linux r39.2.0 release notes for known issue 5251623.
    • Result: The Type-C port on the RJ45 side started recognizing USB devices.
    • However, the QSFP-side Type-C port still did not recognize USB devices even after applying the workaround.
    • Also, the workaround appears to need to be applied again after every boot.
  3. Tested another Jetson AGX Thor Developer Kit unit.
    • Result: The QSFP-side Type-C port also did not recognize a connected USB device on the other unit.
    • Since the same symptom is reproduced on multiple units, we are concerned that this may not be an individual hardware failure, but instead a firmware issue or a design/specification limitation.
According to the Jetson AGX Thor Developer Kit documentation (Hardware Layout — Jetson AGX Thor Developer Kit - User Guide), both Type-C ports appear to be described as supporting DFP / host functionality. Based on that, our understanding is that both J81 and J82 should be usable as USB host ports after the OS has booted.
Could you please help clarify the following points?
  1. Are both J81 and J82 Type-C ports officially supported and guaranteed to operate as USB host ports after the OS boots?
  2. If this behavior is a known issue on Jetson AGX Thor, is there a plan to provide a permanent fix, such as an updated firmware or software release?
  3. Regarding the workaround for issue 5251623, is there a persistent configuration method so that the workaround does not need to be applied manually after every boot?
We would like to determine whether this is a product limitation, a known software/firmware issue, or something that should be handled through RMA.
Best regards,
Could you please provide any update on this issue?
We would appreciate your confirmation on whether the observed behavior is expected or not.
Best regards,
You need to apply device tree change to make both of them to be host mode only and try. This shall work.
Thank you for your reply.
Could you please tell me exactly which file I should edit and exactly where in that file the change should be made?
An example showing the full file path and the before/after change would be very helpful.
Just to clarify. Do you have experience in flashing board with manual command and Linux kernel building?
This might help to tell where to start the guidance. This is not just “modify one file” thing.
