I am using a Jetson AGX Thor Developer Kit with Jetson Linux R39.2.0.
I am trying to use the J82 USB-C port as a USB host, but it does not appear to provide VBUS or detect any USB devices.
Environment
- Board: Jetson AGX Thor Developer Kit
- Jetson Linux: R39.2.0
- Kernel: 6.8.12-1021-tegra
- USB power input: J81
- USB device under test: USB-C hub with an integrated USB-C plug (verified working on another PC)
Symptoms
- The hub LED never turns on when connected to J82.
- No USB devices appear in
lsusb. - No USB-related events appear in
udevadm monitor --kernel. dmesgshows no USB connection events when plugging or unplugging the hub.
The USB role can be changed manually:
echo host | sudo tee /sys/class/usb_role/usb2-0-role-switch/role
The role changes successfully:
host
However, switching none -> host also makes no difference.
Diagnostic Results
USB role
host
Type-C
/sys/class/typec is empty.
$ ls -la /sys/class/typec
total 0
drwxr-xr-x 2 root root 0 ...
drwxr-xr-x ...
UCSI
The modules are loaded:
ucsi_ccg
typec_ucsi
typec
However, ucsi_ccg is not bound to any I2C device.
Boot log
I noticed the following messages during boot:
usb2-0: supply vbus not found, using dummy regulator
usb2-1: supply vbus not found, using dummy regulator
usb2-2: supply vbus not found, using dummy regulator
usb2-3: supply vbus not found, using dummy regulator
USB monitoring
udevadm monitor --kernel only reports thermal events.
No USB events are generated when connecting or disconnecting the hub.
Additional Information
- The same USB-C hub works correctly on another computer.
- USB-A ports on the developer kit work normally.
- The problem is only with J82.
- J81 is being used only for power input.
Question
Is this a known issue in R39.2.0?
Should a Device Tree update or another BSP change be applied to enable J82 host mode and VBUS, or does this behavior indicate a hardware problem requiring RMA?
Thank you.
