Jetson AGX Thor FAN and its connector part details
Could you please share the specifications and part number for the fan and its connector used in the Thor and Orin development kits?
Thank you.
Please refer to Jetson AGX Orin Developer Kit Carrier Board Design Files (A05) Log in | NVIDIA Developer
Jetson Thor Developer Kit Carrier Board Design Files https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/thor/docs/jetson_thor_devkit_carrier_board_design_files.zip
Jetson Download Center | NVIDIA Developer
You could use any 12V fan suitable for your use case.
Thank you. Is it possible to share similar documents for Drive AGX Orin or Thor Developer Carrier Board design?
Thank you
Links already provided in earlier response above for AGX Orin and Jetson Thor carrier board design files. All above design collaterals are available in Jetson Download Center Jetson Download Center | NVIDIA Developer
I thought the Jetson series is for industrial applications and the DRIVE series is for automotive. Can I assume the same files are applicable to the automotive domain as well?
Thank you.
DRIVE Orin / Thor Automotive series of products are not supported in this forum.
Thank you.
For automotive, suggest to try other forum supporting automotive Latest Autonomous Vehicles topics - NVIDIA Developer Forums
