Jetson AGX Thor flashing successfully took 11 minutes, is this expected?
It took about 11 mins to flash the Ubuntu OS image to the Jestson AGX Thor. Is that normal?
It feels way slower than expected.
For me, I check jtop and run a sample gpu kernel. It’s good as long as the packages are installed correct and can run gpu programs
If you used the Jetson ISO method on a Jetson AGX Thor Developer Kit, an 11-minute installation is within the expected range. The current NVIDIA guide lists the Jetson ISO flash time as less than 15 minutes, and the installation steps indicate that the process takes about 10 minutes.
Thanks, everyone above.
