Jetson AGX Thor JP7.1 hangs during reboot after Timeshift live restore
Hellow,
We are encountering a reproducible reboot hang on a Jetson AGX Thor running JetPack 7.1 after restoring a Timeshift snapshot from the live system.
Platform: Jetson AGX Thor [Developer Kit / T5000 with custom carrier board]
JetPack: 7.1
Reproduction steps
Start Timeshift while the system is running.
Restore a snapshot created from [the same JP7.1/r38.4 installation].
Timeshift synchronizes the filesystems and initiates a reboot.
During the reboot/shutdown sequence, the system hangs and does not reset.
A hardware reset or power cycle is required.
After a forced reset, the restored system boots normally.
UART log
The following messages appear when the reboot hangs:
01: base: 80000000 size: 80000000 XN P_RW U_RW Shareable strongly-ordered
02: base: ffff0000 size: 00000040 X P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
03.2: base: 50020000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
03.3: base: 50030000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
03.4: base: 50040000 size: 00010000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.2: base: 50080000 size: 00040000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.3: base: 500c0000 size: 00040000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
04.4: base: 50100000 size: 00040000 X P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
05: base: 50140000 size: 00040000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
06: base: 50200000 size: 00080000 XN P_RO U_NA Non-shareable outer: WB, no WA inner: WB, no WA
07.3: base: 50600000 size: 00200000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
07.4: base: 50800000 size: 00200000 XN P_RO U_RO Non-shareable outer: WB, no WA inner: WB, no WA
09: base: 40000000 size: 00040000 XN P_RW U_NA Non-shareable outer: WB, no WA inner: WB, no WA
15: base: 5020a000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
gisink_thermal sp 0x5020bfa0 stack: 5020a000 - 5020bffc
Per task regions for gisink_thermal
04: base: 5020a000 size: 00002000 XN P_RW U_RW Non-shareable outer: WB, no WA inner: WB, no WA
Enable MMIO: 1, Enable data R/W: 1
call stack:
sp 0x5020bfa0 pc 0x5002091c
sp 0x5020bfa0 pc 0x50020930
sp 0x5020bfb0 pc 0x500a3464
sp 0x5020bfc8 pc 0x500a38f0
sp 0x5020bfd8 pc 0x500c8578
sp 0x5020bff8 pc 0xaaaaaaaa
eht_idx_find: 0xaaaaaaaa not a valid code address
no eidx for 0xaaaaaaaa
▒▒[ 579.000993] mcf_log_fault: 86201 callbacks suppressed
[ 579.005019] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.017944] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.030864] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.043777] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.056690] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.069634] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
[ 579.082528] tegra-mc 8108020000.memory-controller: gpur02mc: non-secure read @0x0000fffffff00020: EMEM address decode error (EMEM decode error)
Would you mind helping me verify the issues mentioned above?
Thank you.
Please upgrade to jp7.2.1 and try again.
Just to confirm, is this a known issue that has already been fixed in JetPack 7.2.1?
