[Jetson AGX Thor][Kubernetes][MIG] NVIDIA k8s-device-plugin exposes only nvidia.com/gpu instead of MIG resources
Hi NVIDIA team,
I am trying to expose MIG instances on a Jetson AGX Thor as schedulable Kubernetes resources.
MIG itself works correctly on the host, and CUDA workloads can run on both MIG instances when the required /dev/ nvidia-caps/* devices are manually exposed to privileged containers. However, the official NVIDIA Kubernetes Device
Plugin currently exposes only one full GPU resource:
  nvidia.com/gpu: 1
It does not expose the two MIG instances as resources such as:
  nvidia.com/mig-1g.0gb: 1
  nvidia.com/mig-2g.0gb: 1
Environment
Device:
NVIDIA Jetson AGX Thor
Jetson Linux:
R39.2.1
GCID: 46758480
Architecture:
aarch64
Kernel:
6.8.12-1021-tegra
NVIDIA driver:
595.78
CUDA:
13.2
NVIDIA Container Toolkit:
1.19.1
Kubernetes:
K3s v1.36.3+k3s1
Container runtime:
containerd 2.3.2-k3s2
NVIDIA Kubernetes Device Plugin:
nvcr.io/nvidia/k8s-device-plugin:v0.18.2
Current Device Plugin configuration
  version: v1
  flags:
    deviceDiscoveryStrategy: tegra
    plugin:
      deviceIDStrategy: index
With this configuration, the plugin starts successfully and the node reports:
  Capacity:
    nvidia.com/gpu: 1
  Allocatable:
    nvidia.com/gpu: 1
MIG configuration
nvidia-smi -L reports:
  GPU 0: NVIDIA Thor
    MIG 2g.0gb Device 0:
      MIG-04c21d66-5860-5f1c-a8e7-4d91cf2c5e2e
    MIG 1g.0gb Device 1:
      MIG-efdd418f-43bb-5070-bf32-28fbcee542a7
The MIG capability minors are:
  GPU instance 1 / compute instance 0:
    /dev/nvidia-caps/nvidia-cap12
    /dev/nvidia-caps/nvidia-cap13
  GPU instance 2 / compute instance 0:
    /dev/nvidia-caps/nvidia-cap21
    /dev/nvidia-caps/nvidia-cap22
The mapping is also present in:
  /proc/driver/nvidia-caps/mig-minors
Observed behavior
When using the Tegra device discovery strategy, the plugin recognizes the
integrated Thor GPU but exposes it only as:
  nvidia.com/gpu: 1
It does not expose individual MIG profiles.
When trying the MIG mixed strategy, the expected resources are not
The MIG instances themselves are functional. As a workaround, I can run two
Kubernetes workloads using:
  runtimeClassName: nvidia
  securityContext:
    privileged: true
  env:
    - name: NVIDIA_VISIBLE_DEVICES
      value: "all"
    - name: CUDA_VISIBLE_DEVICES
      value: "<MIG UUID>"
With this workaround:
  • One workload runs successfully on the 1g MIG instance.
  • Another workload runs successfully on the 2g MIG instance.
  • Both workloads report CUDA as available.
  • nvidia-smi shows each Python process assigned to the expected GI/CI.
I also verified that explicitly exposing the matching
/dev/nvidia-caps/nvidia-cap* devices with device cgroup permissions allows
the containers to use the corresponding MIG instance.
Questions
  1. Is MIG resource discovery on Jetson AGX Thor officially supported by the
    NVIDIA Kubernetes Device Plugin?
  2. Does the tegra device discovery strategy currently support enumerating
    Thor MIG devices, or does MIG discovery still require the NVML discovery
    path?
  3. Is there a supported configuration using:
    migStrategy: mixed
    that exposes Thor resources as nvidia.com/mig-1g.0gb and
    nvidia.com/mig-2g.0gb?
  4. Is there an official way for the Device Plugin or NVIDIA Container
    Toolkit to inject the required /dev/nvidia-caps/nvidia-cap* device nodes
    and device-cgroup permissions into a non-privileged Pod?
Our desired Kubernetes resources are
The goal is to remove privileged: true and let kubelet grant only the
corresponding MIG capability devices to each Pod.
Thanks for your feedback.
This is a known issue and we are working on a fix in nvidia- container toolkit.
