Jetson AGX Thor R38.4: hard stops at 120W/150W under DeepStream load; DC disconnect needed
We are investigating repeated complete board stops under a DeepStream workload. Higher power modes failed sooner in the runs below; the root cause is not yet established. All timestamps are Asia/Shanghai (UTC+08:00).
Environment
Item Value
Platform NVIDIA Jetson AGX Thor Developer Kit
Module P/N 699-13834-0008-500, PCB Rev C.2 (P3834)
Carrier P4071-0000 (rev 0)
L4T / BSP R38.4, GCID 43443517, image built 2025-12-31
BIOS / EDK2 38.4.0-gcid-43443517 (2025-12-30)
Kernel 6.8.12-rt-tegra, aarch64, PREEMPT_RT
NVIDIA driver 580.00
Power 19V DC adapter (reported as stock DevKit PSU in our investigation)
Fleet 3 DevKit units with the same module P/N/revision and carrier. All three have exhibited the same symptom; 6+ hard stops since August 2026. Production-batch relationship is unconfirmed.
Failure symptoms
  • Complete loss of responsiveness under sustained GPU/DeepStream workload.
  • No kernel panic, oops, hard/soft lockup, NVRM Xid, OOM, or storage error was identified in the collected failure evidence. Some journals were rate-limited, so missing errors are not proof that none occurred.
  • No graceful shutdown sequence was recorded; pstore was empty.
  • The captured serial output ends mid-line while the kernel is printing. This does not establish CPU state at the later system stop.
  • Physical observations after failure: power LED on, NIC link LEDs off, fan stopped. We have not instrumented the supply rails.
  • The 2-minute hardware watchdog (NVIDIA Tegra186 WDT, held by PID 1) did not recover these failures.
  • Recovery required disconnecting the 19V DC connector between the PSU and board. Disconnecting the AC side for 30 seconds did not recover the board in our observations. Residual voltage and the reason for this difference have not been established.
Power-mode comparison on one unit
Configured nvpmodel mode Observed result
Mode 2, 90W No failure during an 11.5h+ soak; still running when collected on September 25
Mode 1, 120W Two failures, approximately 27 minutes and 2h18m after boot
MAXN, recorded as 150W Failure; journal spans approximately 11.7 minutes from boot
These are approximate boot-to-stop intervals, not precisely measured workload-start-to-failure times. The sample is small and does not establish a statistical failure rate.
Monitored temperatures in the investigation notes were 40–54 °C. This does not rule out unmonitored hotspots or fast power/thermal transients.
We observed that the selected power mode did not persist across reboots on this setup, so we verify it with nvpmodel -q after every boot.
Workload / reproduction so far
  1. Select 120W (mode 1) or MAXN and verify the active mode with nvpmodel -q.
  2. Run our containerized DeepStream inference workload: RTSP video replay plus application restart-churn scenarios.
  3. Observe the complete board-stop signature above. Higher-power runs failed within minutes to roughly two hours after boot in this set of tests.
  4. Disconnect and reconnect the 19V DC jack to recover.
At 90W, the same workload survived the recorded 11.5h+ soak. We have not yet reduced this to a standalone minimal reproducer. Exact DeepStream/container versions are not in the current evidence summary. Application-level crashes also occurred; their relationship to the board stop is unknown.
Evidence from the first 120W failure (September 24, 2026)
  • Estimated boot time: 16:49:36; workload started around 17:10.
  • Serial capture starts around uptime 291 s and ends around uptime 8254 s, approximately 19:06:10, mid-printk.
  • The persistent journal ends at 19:06:28, while rsyslog continues to 19:07:23.737. The last recorded timesyncd clock-file save is 19:07:08.
  • These differing endpoints do not prove that UART or a power domain failed first; capture buffering and clock alignment remain possible factors.
  • Boot logs contain tegra-i2c 810c630000.i2c: I2C transfer timed out; the investigation counted 10 occurrences in this boot. Its connection to the later failure is unknown.
  • The serial log includes 32 all-CPU NMI backtraces deliberately triggered by the stress harness via /proc/sysrq-trigger. These are not spontaneous watchdog detections.
  • Repeated RTC readings of 2025-07-12 02:52:58 were reported, so RTC time was not used for failure timing. timesyncd persistence was only an additional timing clue, not a direct hardware failure measurement.
Questions for NVIDIA
  1. Is there a known PMIC/BPMP, watchdog, or power-management issue relevant to R38.4 / GCID 43443517 and this hardware revision?
  2. What tests would best distinguish a PSU/carrier/module power issue from a kernel/firmware or workload-triggered issue?
  3. Is there a recommended BSP/firmware update or patch to test, including any relevant differences for the PREEMPT_RT kernel?
  4. Which additional captures would help most? We have raw serial captures, persistent journals, rsyslog failure windows, boot history, and power-mode test notes. Please advise whether Thor Combined UART capture demultiplexed with nv_tcu_demuxer -m T264 would be useful, and which BPMP/DCE/PSC streams or other diagnostics to collect.
Diagnostic logs
Attached are the serial capture, persistent journals, syslog failure windows, host information, and test notes for the 90W, 120W, and 150W runs. See README.txt in the archive for the file inventory and timing notes.
thor-diagnostic-logs.zip (3.2 MB)
Update: extended 90W soak test
As of September 27, 2026, 08:05 (UTC+08:00), the 90W soak test had been running for approximately 57 hours, since September 24 at 23:01:11, with no observed platform hard stop or reboot. The test was still ongoing at that checkpoint.
The workload includes crash-risk, blackbox, and RTSP replay scenarios. Application-level restarts occurred during the crash-risk scenario, but the platform remained operational.
This extends the previously reported 11.5-hour observation. For comparison, the recorded higher-power runs stopped after approximately 27 minutes and 2h18m at 120W, and 11.7 minutes at 150W (approximate boot-to-stop intervals).
The software images used across these runs were substantially the same, with differences mainly in version labels. No substantive software differences have been identified so far. The workload state in the shorter 120W run was not fully confirmed.
The longer 90W run strengthens the observed association with power mode, but does not by itself establish the root cause.
~1028
Could you please help try AGX Thor developer kit with Jetpack 7.2.1? Would like to confirm the issue is present on latest Jetpack version.
