I am trying to create a backup/clone of a configured Jetson AGX Thor (R39.2.0) originally installed via the official USB stick method and flash it onto another Thor device, but the official Workflow (l4t_backup_restore.sh + l4t_initrd_flash.sh) produces a non-bootable result.
Setup:
- Host PC: Ubuntu 24.04
- Jetson AGX Thor Developer Kit (p4071-0000 + p3834-0008, L4T R39.2.0 / JetPack 7.2)
- Initial installation: USB stick method as described in the Quick Start Guide, including QSPI firmware update on first boot
- After setup: Ubuntu 24.04 with ROS 2 Jazzy, RT kernel, and various drivers installed
- Goal: Clone this configured image for deployment on multiple Thors (same approach worked on Orin/R36.x without issues)
Procedure followed: NVIDIA Backup & Restore Guide (R39.2) + Workflow 3 from tools/backup_restore/README_backup_restore.txt
Step 1: Prerequisites
sudo systemctl stop udisks2.service
sudo service nfs-kernel-server start
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh
Step 2: Backup
sudo ./tools/backup_restore/l4t_backup_restore.sh -b -c jetson-agx-thor-devkit
Backup completes successfully. Images stored in tools/backup_restore/images/.
Step 3: Generate massflash package - Multiple Issues
As per Workflow 3 README:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
--use-backup-image --no-flash --network usb0 \
--massflash 5 jetson-agx-thor-devkit internal
Issue 3a: EngSample=True in generated TargetInfo.txt
The generated unified_flash/out/bsp_images/flash_workspace/TargetInfo.txt contains EngSample=True, causing flashing to fail on production-silicon devices:
Aborting, command option -M not allowed with PROD board
Root cause: FUSELEVEL defaults to fuselevel_nofuse for the developer kit, which causes create_l4t_bsp_images.py --internal to be invoked, setting EngSample=True.
Workaround: Set FUSELEVEL=fuselevel_production explicitly:
sudo FUSELEVEL=fuselevel_production \
Issue 3b: s_Skuname empty in jetson-t264.json
After --no-flash, unified_flash/out/bsp_images/tools/flashtools/board_configs/jetson-t264.json contains:
{"jetson-t264": {"s_RamCode": "12", "s_Skuname": ""}}
This causes:
Mismatched Sku TA1090SA
Workaround:
echo '{"jetson-t264": {"s_RamCode": "12", "s_Skuname": "TA1090SA"}}' | sudo tee \
Issue 3c: flash-images directory not generated
When using --use-backup-image, reuse_package=1 is set internally, which skips the flash-images generation block in l4t_initrd_flash_internal.sh (line ~1079). Without flash-images, flash_bsp_images.py fails with:
FileNotFoundError: flash_workspace/flash-images
Additionally, when --use-backup-image is NOT used (to allow flash-images generation), generate_flash_package() overwrites tools/kernel_flash/images/external/ with fresh BSP images, destroying the backup partition data.
Workaround we used:
- Run without
--use-backup-imageto generateflash-imagesbut this produces a fresh Ubuntu install, not the cloned image - Manually re-convert backup images using
convert_backup_image_to_initrd_flashand then callcreate_l4t_bsp_images.pydirectly
Question: What is the correct procedure to generate flash-images from a backup while preserving the backup partition data?
Step 4: Flash the package onto a target device - Python bug + non-bootable result
--flash-only --massflash 5 --network usb0 \
Issue 4a: UnboundLocalError: abs_path in bootburn_adb.py
While flashing the backup’s APP partition (which has Start=0), resizeFilesystem() crashes:
File "bootburn_t264_py/bootburn_adb.py", line 904, in resizeFilesystem
adbOutput = self.AdbShell(abs_path + "e2fsck -yfFt " + LocalPartition)
UnboundLocalError: cannot access local variable 'abs_path' where it is not associated with a value
Root cause: In resizeFilesystem(), abs_path is only assigned inside the if (int(partitionInfo.Start) != 0): block, but is used unconditionally afterwards for the e2fsck / resize2fs calls. For a partition with Start=0, abs_path is never defined.
Workaround: Add abs_path = "" before the if block (must be patched in both unified_flash/tools/flashtools/bootburn_t264_py/bootburn_adb.py and the copy under unified_flash/out/bsp_images/tools/...).
After this patch, flashing completes:
[flash_bsp_jetson-t264]: Flashing finished Successfully!!
Issue 4b: Device does not boot after successful flash - drops to UEFI Shell
Despite the successful flash, the device boots into the UEFI Shell instead of Ubuntu. Investigating from the shell:
map -rshows onlyFS0:,FS1,BLK0- the NVMe partitions are largely not mapped as filesystems -
bcfg boot dumpshows no Ubuntu / Linux boot entry - only generic entries:UEFI HTTPv6 / HTTPv4 / PXEv6 / PXEv4 UEFI WD PC SN5000S (the NVMe SSD) UEFI Shell -
Selecting
UEFI WD PC SN5000Sfrom the Boot Manager briefly refreshes and returns to the menu (does not boot) -
Browsing the mapped filesystems shows no
EFI\ubuntu\orEFI\BOOT\BOOTAA64.EFI- the EFI System Partition appears to be missing or not correctly populated from the backup
This suggests the backup → massflash conversion does not correctly restore/populate the ESP for Thor.
Step 5: Direct restore to a single device - fails at RCM boot (USB timeout)
As an alternative to massflash, we tried restoring the backup directly to a single device (Workflow 2):
sudo ./tools/backup_restore/l4t_backup_restore.sh -r jetson-agx-thor-devkit
Issue 5a: cvm.bin does not exist (EEPROM read fails)
The EEPROM read step fails with a USB timeout, and because the tool renames cvm.bin to cvm.bin.sav before the (failing) read, the restore aborts:
[ 3.0448 ] tegrarcm_v2 --chip 0x26 0 --pollbl --download applet applet_t264_sigheader.bin.encrypt
[ 3.0450 ] ERROR: might be timeout in USB read
Workaround: Restore the saved EEPROM data and skip the EEPROM check:
sudo cp bootloader/cvm.bin.sav bootloader/cvm.bin
sudo cp bootloader/custinfo_out.bin.sav bootloader/custinfo_out.bin
sudo SKIP_EEPROM_CHECK=1 BOARDID=3834 BOARDSKU=0008 FAB=400 BOARDREV=H.1 \
Issue 5b: RCM applet download times out
With the EEPROM check skipped, the flash package generates successfully, but the actual RCM boot of the flashing initrd fails at the applet download:
tegrarcm_v2 --instance /dev/bus/usb/003/027 --chip 0x26 --pollbl --download applet applet/applet_blob.bin
Return code: 8
TEGRARCM -- Unable to execute command
OSError: 43
Note: The same --pollbl --download applet USB timeout appears intermittently in the --flash-only path too, but that workflow apparently tolerates/retries it, whereas the rcm-boot path (used by restore) fails hard.
Open questions:
- What is the correct, supported procedure to create a bootable clone/massflash image of a configured Jetson AGX Thor from a
l4t_backup_restore.sh -b -cbackup? Specifically, how is the EFI System Partition supposed to be preserved and restored? - Are the
EngSample/FUSELEVEL, emptys_Skuname, andabs_pathissues known bugs for R39.2.0, or are we using the wrong invocation? - Is
--use-backup-image --no-flashexpected to work for the Thor /UNIFIED_FLASHflashing architecture? If so, what is the complete correct command sequence? - What causes the
tegrarcm_v2 --pollbl --download appletUSB timeout specifically on thercm-bootpath, and how can it be avoided (cable/port aside)?
