What would be the typical power consumption of the 5V rail on the Jetson AGX Xavier module as we require this to design the 5V power supply onto our board.
Hi, power consumption depends on use case, there are preset nvpmodels for several typical kinds of output power . The maximum output capability of the power source of 5V is 9.5A as you can see in schematic, generally it would be better to follow it.
