But flash will fail and module will reboot.
If I don’t use SKIP_EEPROM_CHECK=1, it can flash successfully.
This problem only happened on one module, other modules can flash with SKIP_EEPROM_CHECK=1.
I test r32.6.1, r32.7.1 and r35.1.0 (on Jetson AGX Xavier DEVKIT board), only r35.1.0 can flash with SKIP_EEPROM_CHECK=1.
Is this module broken? Or is this problem cause by module hardware revision? failed.txt (59.7 KB)
The log is capture from micro-usb port, it’s the log when flash failure.
When flash failure, the module reboot and go into the normal boot-up procedure.
It doesn’t show any other message when failure happened.
I use skip_eeprom_check because I modify MAC without correct checksum in our custom board.
I found that only this module has flash failure problem.
And I move the module to the devkit test again, the problem still happened when skip_eeprom_check .
This will not be SOP, we will use correct checksum.
