Hi
I am testing on the RealSence camera with AGX Xavier.
Actually, there’s no video formats to Y8I, I defined it in vi5_video_formats:
TEGRA_VIDEO_FORMAT(RGB565, 16, RGB565_1X16, 2, 1, T_R5G6B5, USER_3, Y8I, “Y8I 16”),
Which macro will extended to
Here is error output after running
v4l2-ctl -d /dev/video4 --set-fmt-video=width=1280,height=720,pixelformat="Y8I " --stream-mmap=3 --stream-count=5
# tracer: nop
# entries-in-buffer/entries-written: 312/312 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-9226 [002] .... 536.966541: tegra_channel_open: vi-output, DS5 mux 34-0010
v4l2-ctl-9226 [000] .... 536.968742: tegra_channel_set_power: DS5 mux 34-0010 : 0x1
v4l2-ctl-9226 [000] .... 536.968750: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9226 [000] .... 536.968755: csi_s_power: enable : 0x1
v4l2-ctl-9226 [000] .... 536.975870: tegra_channel_capture_setup: vnc_id 0 W 1280 H 720 fmt 1
v4l2-ctl-9226 [000] .... 536.990766: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-9226 [000] .... 536.990773: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9226 [000] .... 536.990777: csi_s_stream: enable : 0x1
v4l2-ctl-9226 [000] .... 536.990789: tegra_channel_set_stream: DS5 mux 34-0010 : 0x1
kworker/0:2-9204 [000] .... 537.013905: rtos_queue_peek_from_isr_failed: tstamp:17674758065 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.013916: rtcpu_start: tstamp:17674760693
kworker/0:2-9204 [000] .... 537.013920: rtos_queue_send_from_isr_failed: tstamp:17674901852 queue:0x0bcb2e38
kworker/0:2-9204 [000] .... 537.013922: rtos_queue_send_from_isr_failed: tstamp:17674902074 queue:0x0bcb76a0
kworker/0:2-9204 [000] .... 537.013923: rtos_queue_send_from_isr_failed: tstamp:17674902294 queue:0x0bcb9220
kworker/0:2-9204 [000] .... 537.013925: rtos_queue_send_from_isr_failed: tstamp:17674902512 queue:0x0bcb9fe0
kworker/0:2-9204 [000] .... 537.013926: rtos_queue_send_from_isr_failed: tstamp:17674902730 queue:0x0bcbada0
kworker/0:2-9204 [000] .... 537.013930: rtcpu_string: tstamp:17674903351 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-9204 [000] .... 537.013985: rtcpu_string: tstamp:17674903666 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:2-9204 [000] .... 537.014038: rtcpu_string: tstamp:17674903994 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:2-9204 [000] .... 537.014047: rtcpu_string: tstamp:17674904311 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:2-9204 [000] .... 537.014055: rtcpu_string: tstamp:17674904617 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:2-9204 [000] .... 537.014063: rtcpu_string: tstamp:17674904959 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:2-9204 [000] .... 537.014071: rtcpu_string: tstamp:17674905265 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:2-9204 [000] .... 537.014079: rtcpu_string: tstamp:17674913375 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:2-9204 [000] .... 537.014081: rtcpu_string: tstamp:17674913573 id:0x04010000 str:"on 2.2
kworker/0:2-9204 [000] .... 537.014127: rtos_queue_send_from_isr_failed: tstamp:17674943896 queue:0x0bcb2e38
kworker/0:2-9204 [000] .... 537.014129: rtos_queue_send_from_isr_failed: tstamp:17674944155 queue:0x0bcb76a0
kworker/0:2-9204 [000] .... 537.014130: rtos_queue_send_from_isr_failed: tstamp:17674944379 queue:0x0bcb9220
kworker/0:2-9204 [000] .... 537.014131: rtos_queue_send_from_isr_failed: tstamp:17674944597 queue:0x0bcb9fe0
kworker/0:2-9204 [000] .... 537.014132: rtos_queue_send_from_isr_failed: tstamp:17674944815 queue:0x0bcbada0
kworker/0:2-9204 [000] .... 537.014133: rtcpu_string: tstamp:17674946153 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:2-9204 [000] .... 537.014143: rtos_queue_send_from_isr_failed: tstamp:17674947471 queue:0x0bcb2e38
kworker/0:2-9204 [000] .... 537.014144: rtos_queue_send_from_isr_failed: tstamp:17674947696 queue:0x0bcb76a0
kworker/0:2-9204 [000] .... 537.014145: rtos_queue_send_from_isr_failed: tstamp:17674947914 queue:0x0bcb9220
kworker/0:2-9204 [000] .... 537.014146: rtos_queue_send_from_isr_failed: tstamp:17674948120 queue:0x0bcb9f78
kworker/0:2-9204 [000] .... 537.014147: rtos_queue_send_from_isr_failed: tstamp:17674948329 queue:0x0bcb9fe0
kworker/0:2-9204 [000] .... 537.014149: rtos_queue_send_from_isr_failed: tstamp:17674948535 queue:0x0bcbad38
kworker/0:2-9204 [000] .... 537.014150: rtos_queue_send_from_isr_failed: tstamp:17674948741 queue:0x0bcbada0
kworker/0:2-9204 [000] .... 537.014154: rtcpu_vinotify_event: tstamp:17675226214 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15842501568 data:0x10000000
kworker/0:2-9204 [000] .... 537.014155: rtcpu_vinotify_event: tstamp:17675226618 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15842505312 data:0x31000001
kworker/0:2-9204 [000] .... 537.014157: rtcpu_vinotify_event: tstamp:17675226969 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15842506304 data:0x07020001
kworker/0:2-9204 [000] .... 537.014158: rtcpu_vinotify_event: tstamp:17675227254 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15842626432 data:0x10000000
kworker/0:2-9204 [000] .... 537.014159: rtcpu_vinotify_event: tstamp:17675227599 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15842630208 data:0x31000002
kworker/0:2-9204 [000] .... 537.181955: rtos_queue_peek_from_isr_failed: tstamp:17679758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.349945: rtos_queue_peek_from_isr_failed: tstamp:17684758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.517957: rtos_queue_peek_from_isr_failed: tstamp:17689758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.573955: rtcpu_vinotify_event: tstamp:17692128718 tag:FS channel:0x02 frame:0 vi_tstamp:17692068206 data:0x00000010
kworker/0:2-9204 [000] .... 537.573964: rtcpu_vinotify_event: tstamp:17692129133 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:17692068206 data:0x00000000
kworker/0:2-9204 [000] .... 537.573965: rtcpu_vinotify_event: tstamp:17692129426 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:17692068459 data:0x00008001
kworker/0:2-9204 [000] .... 537.573966: rtcpu_vinotify_event: tstamp:17692129778 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16390377696 data:0x01020001
kworker/0:2-9204 [000] .... 537.573967: rtcpu_vinotify_event: tstamp:17692474929 tag:FE channel:0x02 frame:0 vi_tstamp:17692473760 data:0x00000020
kworker/0:2-9204 [000] .... 537.573969: rtcpu_vinotify_event: tstamp:17692475283 tag:CHANSEL_SHORT_FRAME channel:0x81 frame:0 vi_tstamp:17692473760 data:0x01000000
kworker/0:2-9204 [000] .... 537.573970: rtcpu_vinotify_event: tstamp:17692475575 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16403348512 data:0x01020001
kworker/0:2-9204 [000] .... 537.573971: rtcpu_vinotify_event: tstamp:17692475925 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:17692473761 data:0x00000000
kworker/0:2-9204 [000] .... 537.573972: rtcpu_vinotify_event: tstamp:17692476213 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16403350272 data:0x07020002
kworker/0:2-9204 [000] .... 537.573973: rtcpu_vinotify_event: tstamp:17692476602 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:16403356192 data:0x10000000
kworker/0:2-9204 [000] .... 537.573974: rtcpu_vinotify_event: tstamp:17692476885 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:16403363072 data:0x31000003
kworker/0:2-9204 [000] .... 537.629944: rtos_queue_peek_from_isr_failed: tstamp:17694758521 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.741887: rtcpu_vinotify_event: tstamp:17698294999 tag:FS channel:0x02 frame:0 vi_tstamp:17698279910 data:0x00000010
kworker/0:2-9204 [000] .... 537.741899: rtcpu_vinotify_event: tstamp:17698295291 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:17698279910 data:0x00000000
kworker/0:2-9204 [000] .... 537.741900: rtcpu_vinotify_event: tstamp:17698295698 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:17698281965 data:0x00008001
kworker/0:2-9204 [000] .... 537.741901: rtcpu_vinotify_event: tstamp:17698295983 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16589209920 data:0x01020002
kworker/0:2-9204 [000] .... 537.797958: rtcpu_vinotify_event: tstamp:17698920952 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:17698723541 data:0x02cf8182
kworker/0:2-9204 [000] .... 537.797967: rtcpu_vinotify_event: tstamp:17698921240 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16603340384 data:0x01020002
kworker/0:2-9204 [000] .... 537.797968: rtcpu_vinotify_event: tstamp:17698921589 tag:FE channel:0x02 frame:0 vi_tstamp:17698723666 data:0x00000020
kworker/0:2-9204 [000] .... 537.797969: rtcpu_vinotify_event: tstamp:17698921874 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:17698723667 data:0x00000000
kworker/0:2-9204 [000] .... 537.797975: rtos_queue_peek_from_isr_failed: tstamp:17699758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.965845: rtcpu_vinotify_event: tstamp:17704555165 tag:FS channel:0x02 frame:0 vi_tstamp:17704529815 data:0x00000010
kworker/0:2-9204 [000] .... 537.965855: rtcpu_vinotify_event: tstamp:17704555453 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:17704529815 data:0x00000000
kworker/0:2-9204 [000] .... 537.965857: rtcpu_vinotify_event: tstamp:17704555802 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:17704531870 data:0x00008001
kworker/0:2-9204 [000] .... 537.965858: rtcpu_vinotify_event: tstamp:17704556087 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16789206912 data:0x01020002
kworker/0:2-9204 [000] .... 537.965863: rtos_queue_peek_from_isr_failed: tstamp:17704758524 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 537.965865: rtcpu_vinotify_event: tstamp:17704974243 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:17704973454 data:0x02cf8182
kworker/0:2-9204 [000] .... 537.965866: rtcpu_vinotify_event: tstamp:17704974532 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:16803337600 data:0x01020002
kworker/0:2-9204 [000] .... 537.965867: rtcpu_vinotify_event: tstamp:17704974881 tag:FE channel:0x02 frame:0 vi_tstamp:17704973578 data:0x00000020
kworker/0:2-9204 [000] .... 537.965868: rtcpu_vinotify_event: tstamp:17704975169 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:17704973579 data:0x00000000
kworker/0:2-9204 [000] .... 538.133839: rtos_queue_peek_from_isr_failed: tstamp:17709758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.189929: rtcpu_vinotify_event: tstamp:17710784084 tag:FS channel:0x02 frame:0 vi_tstamp:17710779727 data:0x00000010
kworker/0:2-9204 [000] .... 538.189978: rtcpu_vinotify_event: tstamp:17710784379 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17710781783 data:0x00000649
kworker/0:2-9204 [000] .... 538.189979: rtcpu_vinotify_event: tstamp:17711410126 tag:FE channel:0x02 frame:0 vi_tstamp:17711223485 data:0x00000020
kworker/0:2-9204 [000] .... 538.301815: rtos_queue_peek_from_isr_failed: tstamp:17714758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.357813: rtcpu_vinotify_event: tstamp:17717044267 tag:FS channel:0x02 frame:0 vi_tstamp:17717029639 data:0x00000010
kworker/0:2-9204 [000] .... 538.357816: rtcpu_vinotify_event: tstamp:17717044618 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17717031688 data:0x00000649
kworker/0:2-9204 [000] .... 538.413809: rtcpu_vinotify_event: tstamp:17717670221 tag:FE channel:0x02 frame:0 vi_tstamp:17717473397 data:0x00000020
kworker/0:2-9204 [000] .... 538.469794: rtos_queue_peek_from_isr_failed: tstamp:17719758526 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.581822: rtcpu_vinotify_event: tstamp:17723304344 tag:FS channel:0x02 frame:0 vi_tstamp:17723279545 data:0x00000010
kworker/0:2-9204 [000] .... 538.581826: rtcpu_vinotify_event: tstamp:17723304636 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17723281601 data:0x00000649
kworker/0:2-9204 [000] .... 538.581828: rtcpu_vinotify_event: tstamp:17723930415 tag:FE channel:0x02 frame:0 vi_tstamp:17723723302 data:0x00000020
kworker/0:2-9204 [000] .... 538.637846: rtos_queue_peek_from_isr_failed: tstamp:17724758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.749821: rtcpu_vinotify_event: tstamp:17729564562 tag:FS channel:0x02 frame:0 vi_tstamp:17729529458 data:0x00000010
kworker/0:2-9204 [000] .... 538.749826: rtcpu_vinotify_event: tstamp:17729564911 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17729531507 data:0x00000649
kworker/0:2-9204 [000] .... 538.749829: rtos_queue_peek_from_isr_failed: tstamp:17729758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.805866: rtcpu_vinotify_event: tstamp:17730190610 tag:FE channel:0x02 frame:0 vi_tstamp:17729973215 data:0x00000020
kworker/0:2-9204 [000] .... 538.917801: rtos_queue_peek_from_isr_failed: tstamp:17734758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 538.973776: rtcpu_vinotify_event: tstamp:17735824688 tag:FS channel:0x02 frame:0 vi_tstamp:17735779364 data:0x00000010
kworker/0:2-9204 [000] .... 538.973780: rtcpu_vinotify_event: tstamp:17735824977 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17735781419 data:0x00000649
kworker/0:2-9204 [000] .... 538.973828: rtcpu_vinotify_event: tstamp:17736450724 tag:FE channel:0x02 frame:0 vi_tstamp:17736223127 data:0x00000020
kworker/0:2-9204 [000] .... 539.085786: rtos_queue_peek_from_isr_failed: tstamp:17739758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.141773: rtcpu_vinotify_event: tstamp:17742029927 tag:FS channel:0x02 frame:0 vi_tstamp:17742029276 data:0x00000010
kworker/0:2-9204 [000] .... 539.197770: rtcpu_vinotify_event: tstamp:17742335256 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17742031331 data:0x00000649
kworker/0:2-9204 [000] .... 539.197773: rtcpu_vinotify_event: tstamp:17742648276 tag:FE channel:0x02 frame:0 vi_tstamp:17742473033 data:0x00000020
kworker/0:2-9204 [000] .... 539.253763: rtos_queue_peek_from_isr_failed: tstamp:17744758517 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.365756: rtcpu_vinotify_event: tstamp:17748282490 tag:FS channel:0x02 frame:0 vi_tstamp:17748279182 data:0x00000010
kworker/0:2-9204 [000] .... 539.365759: rtcpu_vinotify_event: tstamp:17748282791 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17748281238 data:0x00000649
kworker/0:2-9204 [000] .... 539.365760: rtcpu_vinotify_event: tstamp:17748908486 tag:FE channel:0x02 frame:0 vi_tstamp:17748723223 data:0x00000020
kworker/0:2-9204 [000] .... 539.421745: rtos_queue_peek_from_isr_failed: tstamp:17749758517 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.589749: rtcpu_vinotify_event: tstamp:17754542655 tag:FS channel:0x02 frame:0 vi_tstamp:17754529095 data:0x00000010
kworker/0:2-9204 [000] .... 539.589752: rtcpu_vinotify_event: tstamp:17754543010 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17754531149 data:0x00000649
kworker/0:2-9204 [000] .... 539.589754: rtos_queue_peek_from_isr_failed: tstamp:17754758516 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.589756: rtcpu_vinotify_event: tstamp:17755168601 tag:FE channel:0x02 frame:0 vi_tstamp:17754972851 data:0x00000020
kworker/0:2-9204 [000] .... 539.757730: rtos_queue_peek_from_isr_failed: tstamp:17759758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.757735: rtcpu_vinotify_event: tstamp:17760802735 tag:FS channel:0x02 frame:0 vi_tstamp:17760779001 data:0x00000010
kworker/0:2-9204 [000] .... 539.757736: rtcpu_vinotify_event: tstamp:17760803024 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17760781055 data:0x00000649
kworker/0:2-9204 [000] .... 539.813747: rtcpu_vinotify_event: tstamp:17761428788 tag:FE channel:0x02 frame:0 vi_tstamp:17761223041 data:0x00000020
kworker/0:2-9204 [000] .... 539.869734: rtos_queue_peek_from_isr_failed: tstamp:17764758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 539.981730: rtcpu_vinotify_event: tstamp:17767062960 tag:FS channel:0x02 frame:0 vi_tstamp:17767028913 data:0x00000010
kworker/0:2-9204 [000] .... 539.981733: rtcpu_vinotify_event: tstamp:17767063311 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17767030968 data:0x00000649
kworker/0:2-9204 [000] .... 539.981734: rtcpu_vinotify_event: tstamp:17767688998 tag:FE channel:0x02 frame:0 vi_tstamp:17767472670 data:0x00000020
kworker/0:2-9204 [000] .... 540.037895: rtos_queue_peek_from_isr_failed: tstamp:17769758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.149767: rtcpu_vinotify_event: tstamp:17773281760 tag:FS channel:0x02 frame:0 vi_tstamp:17773278819 data:0x00000010
kworker/0:2-9204 [000] .... 540.149771: rtcpu_vinotify_event: tstamp:17773282049 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17773280874 data:0x00000649
kworker/0:2-9204 [000] .... 540.205870: rtcpu_vinotify_event: tstamp:17773730021 tag:FE channel:0x02 frame:0 vi_tstamp:17773722860 data:0x00000020
kworker/0:2-9204 [000] .... 540.205874: rtos_queue_peek_from_isr_failed: tstamp:17774758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.373709: rtcpu_vinotify_event: tstamp:17779677158 tag:FS channel:0x02 frame:0 vi_tstamp:17779528731 data:0x00000010
kworker/0:2-9204 [000] .... 540.373713: rtcpu_vinotify_event: tstamp:17779677511 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17779530787 data:0x00000649
kworker/0:2-9204 [000] .... 540.373715: rtos_queue_peek_from_isr_failed: tstamp:17779758513 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.373717: rtcpu_vinotify_event: tstamp:17779990099 tag:FE channel:0x02 frame:0 vi_tstamp:17779972488 data:0x00000020
kworker/0:2-9204 [000] .... 540.541706: rtos_queue_peek_from_isr_failed: tstamp:17784758517 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.597713: rtcpu_vinotify_event: tstamp:17785937328 tag:FS channel:0x02 frame:0 vi_tstamp:17785778637 data:0x00000010
kworker/0:2-9204 [000] .... 540.597716: rtcpu_vinotify_event: tstamp:17785937624 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17785780692 data:0x00000649
kworker/0:2-9204 [000] .... 540.597717: rtcpu_vinotify_event: tstamp:17786250355 tag:FE channel:0x02 frame:0 vi_tstamp:17786222401 data:0x00000020
kworker/0:2-9204 [000] .... 540.709677: rtos_queue_peek_from_isr_failed: tstamp:17789758517 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.765738: rtcpu_vinotify_event: tstamp:17792197532 tag:FS channel:0x02 frame:0 vi_tstamp:17792028550 data:0x00000010
kworker/0:2-9204 [000] .... 540.765741: rtcpu_vinotify_event: tstamp:17792197883 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17792030605 data:0x00000649
kworker/0:2-9204 [000] .... 540.765743: rtcpu_vinotify_event: tstamp:17792510557 tag:FE channel:0x02 frame:0 vi_tstamp:17792472307 data:0x00000020
kworker/0:2-9204 [000] .... 540.877685: rtos_queue_peek_from_isr_failed: tstamp:17794758525 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 540.989677: rtcpu_vinotify_event: tstamp:17798457730 tag:FS channel:0x02 frame:0 vi_tstamp:17798278462 data:0x00000010
kworker/0:2-9204 [000] .... 540.989679: rtcpu_vinotify_event: tstamp:17798458024 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17798280511 data:0x00000649
kworker/0:2-9204 [000] .... 540.989680: rtcpu_vinotify_event: tstamp:17798770668 tag:FE channel:0x02 frame:0 vi_tstamp:17798722497 data:0x00000020
kworker/0:2-9204 [000] .... 540.989682: rtos_queue_peek_from_isr_failed: tstamp:17799758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.157649: rtcpu_vinotify_event: tstamp:17804717906 tag:FS channel:0x02 frame:0 vi_tstamp:17804528368 data:0x00000010
kworker/0:2-9204 [000] .... 541.157652: rtcpu_vinotify_event: tstamp:17804718262 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17804530424 data:0x00000649
kworker/0:2-9204 [000] .... 541.157654: rtos_queue_peek_from_isr_failed: tstamp:17804758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.157655: rtcpu_vinotify_event: tstamp:17804972779 tag:FE channel:0x02 frame:0 vi_tstamp:17804972126 data:0x00000020
kworker/0:2-9204 [000] .... 541.325796: rtos_queue_peek_from_isr_failed: tstamp:17809758520 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.381669: rtcpu_vinotify_event: tstamp:17810790218 tag:FS channel:0x02 frame:0 vi_tstamp:17810778281 data:0x00000010
kworker/0:2-9204 [000] .... 541.381673: rtcpu_vinotify_event: tstamp:17810790509 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17810780330 data:0x00000649
kworker/0:2-9204 [000] .... 541.381675: rtcpu_vinotify_event: tstamp:17811416261 tag:FE channel:0x02 frame:0 vi_tstamp:17811222038 data:0x00000020
kworker/0:2-9204 [000] .... 541.493708: rtos_queue_peek_from_isr_failed: tstamp:17814758515 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.549660: rtcpu_vinotify_event: tstamp:17817050413 tag:FS channel:0x02 frame:0 vi_tstamp:17817028188 data:0x00000010
kworker/0:2-9204 [000] .... 541.549663: rtcpu_vinotify_event: tstamp:17817050767 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17817030243 data:0x00000649
kworker/0:2-9204 [000] .... 541.605658: rtcpu_vinotify_event: tstamp:17817676449 tag:FE channel:0x02 frame:0 vi_tstamp:17817471944 data:0x00000020
kworker/0:2-9204 [000] .... 541.661631: rtos_queue_peek_from_isr_failed: tstamp:17819758521 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.773629: rtcpu_vinotify_event: tstamp:17823310589 tag:FS channel:0x02 frame:0 vi_tstamp:17823278100 data:0x00000010
kworker/0:2-9204 [000] .... 541.773631: rtcpu_vinotify_event: tstamp:17823310885 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17823280155 data:0x00000649
kworker/0:2-9204 [000] .... 541.773633: rtcpu_vinotify_event: tstamp:17823936528 tag:FE channel:0x02 frame:0 vi_tstamp:17823722134 data:0x00000020
kworker/0:2-9204 [000] .... 541.829715: rtos_queue_peek_from_isr_failed: tstamp:17824758517 queue:0x0bcbbbb8
kworker/0:2-9204 [000] .... 541.941652: rtcpu_vinotify_event: tstamp:17829570728 tag:FS channel:0x02 frame:0 vi_tstamp:17829528006 data:0x00000010
kworker/0:2-9204 [000] .... 541.941655: rtcpu_vinotify_event: tstamp:17829571082 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:17829530062 data:0x00000649
Referred to Jetson/l4t/Camera BringUp - eLinux.org, parse the error to
---> 0b1011001111 1000 0001 1000 0010
bit 1: PIXEL_EOF
bit 7: PIXEL_SOURIOUS
bit 8: PIXEL_LONG_LINE
bit 15: DTYPE_MISMATCH
bit 16:31 LINE_NUMBER --> 719 (actually, test on 1280x720)
CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:74977661955 data:0x00000649 - 0b110010 0100 1
bit 5-10: NvCsiDataType_User_3 0x32
The data type NvCsiDataType_User_3 0x32 is consistent with the definition inTEGRA_VIDEO_FORMAT(RGB565, 16, RGB565_1X16, 2, 1, T_R5G6B5, USER_3, Y8I, “Y8I 16”), as it’s TEGRA_IMAGE_DT_USER_3. But from CHANSEL_FAULT and CHANSEL_NOMATCH, still got DTYPE_MISMATCH while the LINE_NUMBER 719 is not matched with my setting 1280x720.
Can anyone help figure out these issues? thanks
