Jetson AGX Xavier create_osd ERROR
**•設備:Jetson AGX Xavier
**•Package:nvidia-jecpack Version :5.0.1
**• DeepStream Version 6.1.1
• TensorRT Version 8.4.0
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA11.4
• Issue Type (questions)
您好,我在使用Jetson AGX Xavier執行程式的時候會出現以下錯誤
DeepStream版本為6.1.1,nvidia-jecpack為Version :5.0.1
想請問該如何解決這個問題
** ERROR: <create_osd_bin:62>: Failed to create ‘nvosd0’
** ERROR: <create_osd_bin:99>: create_osd_bin failed
** ERROR: <create_processing_instance:815>: create_processing_instance failed
** ERROR: <create_pipeline:1327>: create_pipeline failed
** ERROR: main:697: Failed to create pipeline
Quitting
App run failed
Jetpack 5.0.1 is a DP(Develop Preview) version and only used to bringup platform. Please upgrade to JP5.0.2GA or JP5.1 and then test.
我的Jetson AGX Xavier主機Package:nvidia-jecpack Version :5.0.1
但是下載了官方網站的6.1.1-triton container來運行,內部的Package:nvidia-jecpack Version 為5.0.2
在container內運行一樣有這個錯誤在
There are some dependencies between OS libraries.
Please upgrade to the same JetPack and try it again.
