Suddenly, our Jetson AGX Xavier developer kit stopped booting. We tried reflashing multiple times to different Jetpack versions using the official SDK manager and it always seems to work fine. But when booting, there is no display output at all.
The debugging interface (micro-USB) gives the output attached to this file. It basically ends with
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
I’ve checked your logs. It seems your board stuck at bootloader(UEFI) and not trigger kernel up. The empty line in UEFI is expected. I found an unexpected message as follow.
[0002.143] E> Failed to get board id info!
Does your board could work before?
Could you help to share the flash log from the host for further check?
It seems fine in the flash log with flashing into NVMe drive.
Can your devkit boot up successfully w/o external storage connected?
(i.e. boot up with internal eMMC)
