I am trying to flash the Jetson AGX Xavier. As attached snapshot, its not flashing the agx module and I can only visually see “connecting” but not moving ahead.
Setup :
1> Host PC have Ubuntu 18.4 installed.
2> Host PC is connected on ethernet.
3> Jetson AGX Xavier is provided with following connections:
3.1> Connected to monitor via HDMI.
3.2> Ethernet port is connect and is on the same network with host PC.
3.3> Mouse and keyboard connected via usb.
3.4> AGX is connected with host pc via usb.
4> AGX is in in recovery mode.
5> Jetpack 4.6 installed successfully on host PC.
After all above mentioned setup, when I run sdkmanager, issue appear during step 3 (refer snapshot].
Once I hit “FLASH” option, it just showing connecting but never move ahead.
Can anyone help me to detect the issue? Is there any network setting required? I set it default to 192.168.55.1.
Any help will be highly appreciable .
Regards
