Hey guys, i am working on a program which use AGX Xavier Industrial as Endpoint, when i run this command
./flash.sh jetson-agx-xavier-devkit mmcblk0p1
it always stuck in “tegrarcm_v2 --isapplet”
the environment is Ubuntu 20.0, the micor USB is from AGX Xavier series box
i havent try on sdkmanager, it take too much time.
the flashing command in the same environment could run successful in AGX Xavier series.
I cant found out the differences between AGX Xavier and AGX Xavier Industrial.
Am I doing anything wrong?
Wrong board conf is in use in your flash.sh command.
I did’t see the right configuration command about the industrial version in the documentation, can I ask what the correct one should be?
You can list out what *conf files are under your Linux_for_Tegra. And you will find out the answer.
./flash.sh jetson-xavier mmcblk0p1
is this the right one?
Nope. List them out first.
Thanku so much, i found the right conf!!Thanks again
