Also want to double confirm that your host is able to flash Jetson AGX Xavier module and you know how to flash the board (put into RCM mode, with correct usb type C port).
I mean flashing the non- industrial module.
The non-industrial Xavier is powered when on the developer kit and boots to its own preprogrammed image it came with. When put into force recovery mode (connected to correct USB Type C port and pressing and holding the middle then power buttons, releasing simultaneously after) and entering SDKManager, flashing the non-industrialâsince it has already been flashedâhas it to go into automatic setup, which is different than the manual first time setup we need to do (and have been unable to do) for the industrial Xavier module.
Please let me know if I am missing any steps for putting it into RCM mode or other flashing, for either module.
There is no ârelease simultaneouslyâ. The recovery button is always the last one get released.
If the board would auto-power on, then you can use the reset button. Press rec â rec + reset â release reset â release rec.
Think of the recovery button as being a shift key on a keyboard, only it modifies power on or power reset. Just like typing a capital âXâ, where you hold down the shift key then tap the âxâ key, followed by letting go of the shift key. The instant you have completed the start of either power on or power reset you can let go of the recovery button. If the recovery button remains on during a flash it wonât change anything, but during a flash the Jetson reboots after completing thisâŠand youâd possibly have problems if the recovery button is still down during a reboot (I did not bother to test though).
@WayneWWW @linuxdev thank you for your responses. However, I am still seeing the same issues when I ensured that I was pressing and releasing according to your written procedure.
I have been unable to flash both the industrial and commercial modules:
The commercial (non-industrial) goes straight to automatic setup as seen before and expected, but has the error-in-flashing issue as shown in the attached image. I believe its existing OS could still be running even though I did the force recovery power-on process.
The industrial, when attempting its first flash using manual setup, sees the âwrong device is detectedâ issue as we all have been seeing before.
For both attempts, I did have the warning that there was not enough space on device/sda1, as seen below. I believe this could be critical but did not know how to go about clearing space on the device, so any direction on that would be greatly appreciated as well.
I previously shared my devkitâs and industrial moduleâs SN so if you think that it could be an issue with my devkit or module(s) itself please do let me know. I am unsure why we are seeing this âwrong device is detectedâ on flashing the industrial module and would love some insight on that as wellâthank you so much for your assistance and I look forward to your reply.
I just got another issue from this guy. Maybe this is a bug from SDKM.
Can you directly try with flash.sh?
I think the problem here is some jetson AGXI module gives out a weird 0955:7919 usb number when you check âlsusbâ command on the host side. But sdkmanager does not recognize such device.
Please help me clarify your device usb number first.
Please refer to the posts I shared. There is the command to run flash.sh.
BTW, can you take a photo of how is the connection of your device? I mean those usb type C ports.
Below is the USB-type C connection being made.
Also mentioned on that post.
~/nvidia
If you didnât change the default path of sdkmanager installation path.
After navigating to /nvidia/nvidia_sdk/Jetpack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra, I was able to run sudo ./flash.sh jetson-agx-xavier-industrial mmcblk0p1 and flash the industrial module finally! :)
The industrial boots up to the base Nvidia image now and is working as expected so far, so using flash.sh directly did work whereas using SDKManager did not at this time. Now I will be trying to work on our own carrierboard and loading our version of the Nvidia image.
Thank you so much for your help and please do let me know if you have any other questions or concerns about this [hopefully] closing issue!
Seems a bug in sdkmanager. We will try to fix this.
