Jetson AGX Xavier Industrial Module power consumption
Hi
We want to develop Carrier board for Jetson AGX Xavier industrial module. We need information on power consumption for the two voltage rails SYS_VIN_MV (5V) and SYS_VIN_HV (12V). So can you please help us on how to get the power consumption based on my working application?
Hi, the real power consumption depends on use case. You can run your application on devkit to get that.
Hi
What is the Max power on delay can be acceptable between SYS_VIN_HV (12V) and SYS_VIN_MV (5V) power enables in power sequencing?
There is no strict timing request on that. You can refer to the reference carrier board schematic design for detail circuit.
