Jetson AGX Xavier Module 32GB / TX2 Module 8GB
I got two different production modules that AGX Xavier and TX2.
I tried Kernel Image Fusing but each iot seemed problem.
Are these same iot product or i have to do differently when i do with AGX Xavier or TX2 Module?
please help with this.
hello iskay89,
Jetson AGX Xavier and Jetson TX2 are different modules. you may also refer to Technical Specifications for checking the difference.
you may download JetPack release image via SDK Manager, it’ll install the release image to your local host machine, (i.e. Ubuntu Desktop 16.04 and 18.04 on x64 system).
after that, you may perform flash script to re-flash the board.
you should also check Flash Script Usage by using -k kernel options to update kernel images.
thanks
