I am attempting to setup PXE booting for the Jetson AGX Xavier. My plan was to use the net booting boot process in CBoot to have the Jetson grab the pxelinux.0 executable from the TFTP server as its bootfile and then PXE Boot from there. However, after modifying the boot order in cbo.dtb and flashing onto the device, the net boot process stalls at “Wait till auto-calibration completes…”, as seen below. Any idea as to what could be causing this or how I can get around this?
[0000.188] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.196] I> MB1 (prd-version: 1.5.1.9-t194-41334769-73a9b7ef)
[0000.202] I> Boot-mode: Coldboot
[0000.205] I> Chip revision : A02P
[0000.208] I> Bootrom patch version : 15 (correctly patched)
[0000.213] I> ATE fuse revision : 0x200
[0000.216] I> Ram repair fuse : 0x0
[0000.219] I> Ram Code : 0x2
[0000.222] I> rst_source : 0x0
[0000.225] I> rst_level : 0x0
[0000.228] I> Boot-device: eMMC
[0000.243] I> sdmmc DDR50 mode
[0000.247] W> No valid slot number is found in scratch register
[0000.253] W> Return default slot: _a
[0000.256] I> Active Boot chain : 0
[0000.259] I> Boot-device: eMMC
[0000.263] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.271] I> Temperature = 42000
[0000.274] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.278] W> Skipping boost for clk: BPMP_APB
[0000.282] W> Skipping boost for clk: AXI_CBB
[0000.286] W> Skipping boost for clk: AON_CPU_NIC
[0000.290] W> Skipping boost for clk: CAN1
[0000.294] W> Skipping boost for clk: CAN2
[0000.298] I> Boot-device: eMMC
[0000.301] I> Boot-device: eMMC
[0000.311] I> Sdmmc: HS400 mode enabled
[0000.315] I> ECC region[0]: Start:0x0, End:0x0
[0000.319] I> ECC region[1]: Start:0x0, End:0x0
[0000.323] I> ECC region[2]: Start:0x0, End:0x0
[0000.327] I> ECC region[3]: Start:0x0, End:0x0
[0000.332] I> ECC region[4]: Start:0x0, End:0x0
[0000.336] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.341] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.346] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.350] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.355] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.360] E> FAILED: Thermal config
[0000.367] E> FAILED: MEMIO rail config
[0000.386] I> Boot-device: eMMC
[0000.395] I> sdmmc bdev is already initialized
[0000.470] I> MB1 done
▒▒▒▒main enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
[0000.479] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-6fc80c72)
[0000.479] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.480] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.481] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.486] W> device prod register failed
[0000.490] I> gpio framework initialized
[0000.494] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.501] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.509] I> No valid sdcard_params in mb1_bct
[0000.513] I> Boot-device: eMMC
[0000.516] I> Boot_device: SDMMC_BOOT instance: 3
[0000.526] I> sdmmc-3 params source = boot args
[0000.526] I> sdmmc bdev is already initialized
[0000.529] I> sdmmc-3 params source = boot args
[0000.563] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0000.579] I> Found 42 partitions in SDMMC_USER (instance 3)
[0000.580] W> No valid slot number is found in scratch register
[0000.581] W> Return default slot: _a
[0000.581] I> Active Boot chain : 0
[0000.587] I> parsing oem signed section of bpmp-fw header done
[0000.594] I> bpmp-fw binary init read from storage
[0000.595] I> oem authentication of bpmp-fw header done
[0000.598] I> bpmp-fw binary done read from storage
[0000.598] I> bpmp-fw: Authentication init Done
[0000.605] I> parsing oem signed section of cpubl header done
[0000.611] I> cpubl binary init read from storage
[0000.612] I> bpmp-fw: Authentication Finalize Done
[0000.613] I> oem authentication of cpubl header done
[0000.615] I> cpubl binary done read from storage
[0000.620] I> cpubl: Authentication init Done
[0000.630] I> parsing oem signed section of rce header done
[0000.637] I> rce binary init read from storage
[0000.638] I> Relocating BR-BCT
[0000.638] I> cpubl: Authentication Finalize Done
[0000.641] I> oem authentication of rce header done
[0000.646] I> rce binary done read from storage
[0000.650] I> rce: Authentication init Done
[0000.660] I> parsing oem signed section of ape header done
[0000.667] I> ape binary init read from storage
[0000.667] I> rce: Authentication Finalize Done
[0000.668] I> oem authentication of ape header done
[0000.672] I> ape binary done read from storage
[0000.677] I> ape: Authentication init Done
[0000.687] I> parsing oem signed section of tos header done
[0000.694] I> tos binary init read from storage
[0000.694] I> ape: Authentication Finalize Done
[0000.695] I> oem authentication of tos header done
[0000.699] I> tos binary done read from storage
[0000.704] I> tos: Authentication init Done
[0000.714] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.720] I> bpmp-fw-dtb binary init read from storage
[0000.721] I> tos: Authentication Finalize Done
[0000.725] I> oem authentication of bpmp-fw-dtb header done
[0000.731] I> bpmp-fw-dtb binary done read from storage
[0000.733] I> bpmp-fw-dtb: Authentication init Done
[0000.744] I> parsing oem signed section of cpubl-dtb header done
[0000.751] I> cpubl-dtb binary init read from storage
[0000.751] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.787] I> oem authentication of cpubl-dtb header done
[0000.787] I> cpubl-dtb binary done read from storage
[0000.788] I> cpubl-dtb: Authentication init Done
[0000.795] I> parsing oem signed section of eks header done
[0000.801] I> eks binary init read from storage
[0000.802] I> cpubl-dtb: Authentication Finalize Done
[0000.802] I> oem authentication of eks header done
[0000.803] I> eks binary done read from storage
[0000.804] I> eks: Authentication init Done
[0000.804] I> eks: Authentication Finalize Done
[0000.808] I> EKB detected (length: 0x410) @ VA:0x52700400
▒▒NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 02:21:00, Apr 17 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
[0001.312] I> Welcome to Cboot
▒▒mrq initialized
fmon_post initialized
▒▒[0001.313] I> Cboot Version: .06.10.2022.23-t194-d195e61b
[0001.313] I> CPU-BL Params @ 0xf2820000
[0001.314] I> 0) Base:0x00000000 Size:0x00000000
[0001.318] I> 1) Base:0xf1100000 Size:0x00100000
[0001.323] I> 2) Base:0xf2000000 Size:0x00200000
[0001.327] I> 3) Base:0xf1200000 Size:0x00200000
[0001.332] I> 4) Base:0xf1000000 Size:0x00100000
▒▒clk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
▒▒[0001.336] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.416] I> 6) Base:0xf3800000 Size:0x00400000
[0001.420] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.424] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.429] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.433] I> 10) Base:0xf3000000 Size:0x00800000
[0001.438] I> 11) Base:0x40000000 Size:0x00040000
[0001.442] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.447] I> 13) Base:0x40046000 Size:0x00002000
[0001.451] I> 14) Base:0x40048000 Size:0x00002000▒▒emc_debugfs initialized
dvs_debugfs initialized
[0001.460] I> 15) Base:0xac000000 Size:0x00004000▒▒fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
[0001.511] I> 16) Base:0x4004a000 Size:0x00002000
[0001.515] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.520] I> 18) Base:0x4004c000 Size:0x00002000
[0001.524] I> 19) Base:0xf2200000 Size:0x00600000
[0001.529] I> 20) Base:0x4004e000 Size:0x00002000
[0001.533] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.538] I> 22) Base:0x00000000 Size:0x00000000
[0001.542] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.547] I> 24) Base:0xf6000000 Size:0x02000000
[0001.551] I> 25) Base:0x40050000 Size:0x00002000
[0001.556] I> 26) Base:0x40040000 Size:0x00006000
[0001.560] I> 27) Base:0xf1800000 Size:0x00400000
[0001.564] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.569] I> 29) Base:0xf1400000 Size:0x00400000
[0001.573] I> 30) Base:0x00000000 Size:0x00000000
[0001.578] I> 31) Base:0x00000000 Size:0x00000000
[0001.582] I> 32) Base:0xf8000000 Size:0x08000000
[0001.587] I> 33) Base:0x00000000 Size:0x00000000
[0001.591] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.596] I> 35) Base:0xab000000 Size:0x01000000
[0001.600] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.605] I> 37) Base:0xf2800000 Size:0x00800000
[0001.609] I> 38) Base:0x80000000 Size:0x20000000
[0001.614] I> 39) Base:0xb0000000 Size:0x08000000
[0001.618] I> 40) Base:0x00000000 Size:0x00000000
[0001.622] I> 41) Base:0x00000000 Size:0x00000000
[0001.627] I> 42) Base:0x00000000 Size:0x00000000
[0001.631] I> 43) Base:0x00000000 Size:0x00000000
[0001.636] I> 44) Base:0x00000000 Size:0x00000000
[0001.640] I> 45) Base:0x00000000 Size:0x00000000
[0001.645] GIC-SPI Target CPU: 0
[0001.648] Interrupts Init done
[0001.651] calling constructors
[0001.654] initializing heap
[0001.656] I> Heap: [0xa068a2b0 ... 0xab000000]
[0001.660] initializing threads
[0001.663] initializing timers
[0001.666] creating bootstrap completion thread
[0001.670] top of bootstrap2()
[0001.673] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.678] initializing platform
[0001.681] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.686] W> device prod register failed
[0001.690] I> Bl_dtb @0xaaf00000
[0001.693] I> gpio framework initialized
[0001.701] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.707] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.712] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.720] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.727] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.734] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.740] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.747] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.755] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.761] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.769] I> fixed regulator driver initialized
[0001.782] I> register 'maxim' power off handle
[0001.783] I> virtual i2c enabled
[0001.783] I> registered 'maxim,max20024' pmic
[0001.784] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0001.790] I> Boot-device: eMMC
[0001.793] I> Boot_device: SDMMC_BOOT instance: 3
[0001.799] I> sdmmc-3 params source = boot args
[0001.802] I> sdmmc bdev is already initialized
[0001.806] I> sdmmc-3 params source = boot args
[0001.812] I> Found 128 partitions in SDMMC_BOOT (instance 3)
[0001.818] I> Found 128 partitions in SDMMC_BOOT (instance 3)
[0001.821] I> Load in CBoot Boot Options partition and parse it
[0001.827] I> parse_boot_order: boot-order :-
[0001.831] I> 1.net
[0001.833] I> 2.sd
[0001.835] I> 3.usb
[0001.836] I> 4.nvme
[0001.838] I> 5.emmc
[0001.840] I> tftp-ip: 192.168.10.103
[0001.844] W> parse_ip_info: static-ip info is not required, only tftp-server-ip is required.
[0001.853] E> "plugin-manager" doesn't exist, creating
[0001.857] E> "ids" doesn't exist, creating
[0001.861] E> "connection" doesn't exist, creating
[0001.866] E> "configs" doesn't exist, creating
[0001.871] I> Find /i2c@3160000's alias i2c0
[0001.874] I> Reading eeprom i2c=0 address=0x50
[0001.904] I> Device at /i2c@3160000:0x50
[0001.905] I> Reading eeprom i2c=0 address=0x56
[0001.905] E> I2C: slave not found in slaves.
[0001.905] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.906] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.907] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.914] E> eeprom: Failed to read I2C slave device
[0001.919] I> Eeprom read failed 0x3526070d
[0001.924] I> Find /i2c@3180000's alias i2c2
[0001.927] I> Reading eeprom i2c=2 address=0x54
[0001.933] E> I2C: slave not found in slaves.
[0001.935] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.943] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.949] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.958] E> eeprom: Failed to read I2C slave device
[0001.963] I> Eeprom read failed 0x3526070d
[0001.967] I> Reading eeprom i2c=2 address=0x57
[0001.972] E> I2C: slave not found in slaves.
[0001.976] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.983] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.989] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.998] E> eeprom: Failed to read I2C slave device
[0002.003] I> Eeprom read failed 0x3526070d
[0002.007] I> Reading eeprom i2c=2 address=0x52
[0002.012] E> I2C: slave not found in slaves.
[0002.016] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.023] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.029] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.039] E> eeprom: Failed to read I2C slave device
[0002.043] I> Eeprom read failed 0x3526070d
[0002.048] I> Find /i2c@c240000's alias i2c1
[0002.051] I> Reading eeprom i2c=1 address=0x52
[0002.057] E> I2C: slave not found in slaves.
[0002.060] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.068] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.073] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.083] E> eeprom: Retry to read I2C slave device.
[0002.088] E> I2C: slave not found in slaves.
[0002.092] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.099] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.105] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.114] E> eeprom: Failed to read I2C slave device
[0002.119] I> Eeprom read failed 0x3526070d
[0002.123] I> Reading eeprom i2c=1 address=0x50
[0002.128] E> I2C: slave not found in slaves.
[0002.132] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.139] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.145] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.155] E> eeprom: Retry to read I2C slave device.
[0002.159] E> I2C: slave not found in slaves.
[0002.163] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.171] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.177] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.186] E> eeprom: Failed to read I2C slave device
[0002.191] I> Eeprom read failed 0x3526070d
[0002.195] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.200] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.211] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.219] E> "i2c@3160000" doesn't exist, creating
[0002.223] E> "module@0x50" doesn't exist, creating
[0002.229] I> Adding plugin-manager/cvm
[0002.231] E> "chip-id" doesn't exist, creating
[0002.235] I> Adding plugin-manager/chip-id/A02P
[0002.240] I> Plugin-manager override starting
[0002.245] I> Disable plugin-manager status in FDT
[0002.249] I> Plugin-manager override finished successfully
[0002.261] E> no regulator info present for avdd_hdmi-supply
[0002.262] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.269] E> no regulator info present for avdd_hdmi-supply
[0002.271] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.278] E> cannot find any other nvdisp nodes
[0002.282] E> no valid display unit config found in dtb
[0002.288] W> display init failed
[0002.290] initializing target
[0002.292] calling apps_init()
[0002.295] starting app kernel_boot_app
[0002.301] I> found decompressor handler: lz4-legacy
[0002.304] I> decompressing BMP blob ...
[0002.318] I> Kernel type = Normal
[0002.318] I> Loading kernel & kernel-dtb from network ...
[0002.319] I> EQoS: Init
[0004.321] I> Wait till auto-calibration completes...
Thanks in advance for any help.
