Jetson AGX Xavier Nvidia vision, Machine Learning and AI libraries
Can you please let me know how can I include Nvidia vision, Machine Learning and AI libraries in L4T for Xavier AGX?
The package can be installed via JetPack components below:
Hi, I am building BSP for my custom board based on L4T sources and I want to build it for EMMC module, Can I include them during BSP building? or I need to install them once BSP is flashed?
The installation need to be applied after the system is flashed.
Thanks,
If I want to include these libraries during BSP build using tegra_defconfig, then what is the procedure?
Also how to validate them?
These are stand-alone libraries so you should install them after flashing.
thank you for the info
