So currently i try to run this git project, GitHub - hccho2/wavenet-tf.layers.conv1d: wavenet, dilation convolution tf.layers.conv1d, fast wavenet generation
I installed tensorflow 1.15.2 like this:
sudo pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v44 tensorflow==1.15.2
Then i try to run the following command from the git
sudo python3 train.py --data_dir="/home/ark626/Billy Talent" --logdir="/home/ark626/ai/BillyTalent"
And the result is always a segmentation fault at this line wavenet-tf.layers.conv1d/train.py at 5d8166d39aba27928429276c83caf59ce0f4ae3a · hccho2/wavenet-tf.layers.conv1d · GitHub
Most of the issues with librosa etc i got fixed somehow but here it seems to not work.
Installed packages below.
librosa in /usr/local/lib/python3.6/dist-packages (0.5.0) Requirement already satisfied: joblib>=0.7.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (0.14.1) Requirement already satisfied: scikit-learn>=0.14.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (0.23.0) Requirement already satisfied: decorator>=3.0.0 in /usr/lib/python3/dist-packages (from librosa) (4.1.2) Requirement already satisfied: resampy>=0.1.2 in /usr/local/lib/python3.6/dist-packages (from librosa) (0.2.2) Requirement already satisfied: numpy>=1.8.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (1.16.1) Requirement already satisfied: scipy>=0.13.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (1.4.1) Requirement already satisfied: six>=1.3 in /home/ark626/.local/lib/python3.6/site-packages (from librosa) (1.14.0) Requirement already satisfied: audioread>=2.0.0 in /usr/local/lib/python3.6/dist-packages (from librosa) (2.1.8) Requirement already satisfied: threadpoolctl>=2.0.0 in /usr/local/lib/python3.6/dist-packages (from scikit-learn>=0.14.0->librosa) (2.0.0) Requirement already satisfied: numba>=0.32 in /usr/local/lib/python3.6/dist-packages (from resampy>=0.1.2->librosa) (0.42.0) Requirement already satisfied: llvmlite>=0.27.0dev0 in /usr/local/lib/python3.6/dist-packages (from numba>=0.32->resampy>=0.1.2->librosa) (0.32.1)
dmesg LOG:
[ 8114.805485] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 510 unbind failed, tearing down TSG 0
[ 8139.415356] CPU2: Booted secondary processor [4e0f0040]
[ 8139.438539] ras_fhi_enable: FHI 480 enabled on CPU2
[ 8139.438700] carmel_ras_enable: RAS enabled on cpu2
[ 8139.457637] CPU3: Booted secondary processor [4e0f0040]
[ 8139.473497] ras_fhi_enable: FHI 481 enabled on CPU3
[ 8139.473605] carmel_ras_enable: RAS enabled on cpu3
[ 8139.491122] CPU4: Booted secondary processor [4e0f0040]
[ 8139.502383] ras_fhi_enable: FHI 482 enabled on CPU4
[ 8139.502571] carmel_ras_enable: RAS enabled on cpu4
[ 8139.520444] CPU5: Booted secondary processor [4e0f0040]
[ 8139.530007] ras_fhi_enable: FHI 483 enabled on CPU5
[ 8139.530141] carmel_ras_enable: RAS enabled on cpu5
[ 8139.555474] CPU6: Booted secondary processor [4e0f0040]
[ 8139.566389] ras_fhi_enable: FHI 484 enabled on CPU6
[ 8139.566586] carmel_ras_enable: RAS enabled on cpu6
[ 8139.594388] CPU7: Booted secondary processor [4e0f0040]
[ 8139.598070] ras_fhi_enable: FHI 485 enabled on CPU7
[ 8139.598177] carmel_ras_enable: RAS enabled on cpu7
[ 8139.617831] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 8276.150491] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 510 to be removed from TSG 0 has NEXT set!
[ 8276.150731] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 510 unbind failed, tearing down TSG 0
[ 8967.239609] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[ 8967.239850] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
[ 9554.655969] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[ 9554.656241] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
[10782.645552] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[10782.645793] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
[11086.759649] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[11086.759893] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
[11331.803615] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[11331.803853] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
[12750.009863] nvgpu: 17000000.gv11b gk20a_fifo_tsg_unbind_channel_verify_status:2200 [ERR] Channel 508 to be removed from TSG 0 has NEXT set!
[12750.010117] nvgpu: 17000000.gv11b gk20a_tsg_unbind_channel:164 [ERR] Channel 508 unbind failed, tearing down TSG 0
